Thanks for the compliments and to all who responded to my post regarding seat set up. After at least 20 attempts over several hours one of my trips to the garage paid off i went thru the video that ginger has on u tube and boom they came alive and functioned as they should. After what required alot of stamina i took my car for a spin, came back and the settings were lost. Went thru he process again with no luck.
guess i'll get used to holding the button.😎 A 1989 restoration i did of my 69 big block 390hp
Touching the position buttons momentarily does not cause the seats to go to their setting. One has to hold the buttons until the position has moved.
I had this issue and switched fobs and things started working. Is there a way to determine which fob is 1 and which is 2 short of a reprogram of the keys??
