Convertible top issue
Old Jul 7, 2023 | 03:05 PM
OzarksVette's Avatar
OzarksVette
3rd Gear
Default Convertible top issue
Has anyone had experience with the power top being intermittently inoperative? My 2019 GS (18,000 mi.) is currently at the dealership for this issue. They don't seem to know what causes this. I've had the experience of trying to close the top after a few of hours of top down driving and nothing happens. But, later the top will close when the switch is pressed. Conversely, the top would not open, but performed perfectly when I was at the dealership.
Old Jul 7, 2023 | 03:42 PM
15 Z51 conv's Avatar
15 Z51 conv
2024 C7 of the Year Finalist - Modified
Default Remote
My top would stop about half way and I would have to hit the unlock button and then the top button and it would continue…I later realized after I changed the remote battery, I had no more problems. I think the remote losses it’s signal strength as the battery gets weak and therefore stops the top from moving
Old Aug 5, 2023 | 10:54 AM
OzarksVette
3rd Gear
Picked the car up today, 3 weeks in the dealership 10 hrs diagnostic time and some help from General Motors Tech, It seems to work all the time now. Parts replaced:
Roof Retractable Position Sensor - GM (22942810)
Driver Side Folding Top Cylinder - GM (22942840)
Driver Side Roof Retractable Rear Side Headlining Trim Panel - GM (22863993)
Passenger Side Roof Retractable Rear Side Headliner Trim Panel - GM (22863994
Old Aug 6, 2023 | 02:01 AM
Vette Jockey's Avatar
Vette Jockey
Roadster Madness. 😠
St. Jude Donor '13, '20-'21
Outstanding, that they were able to fix it!
Old Aug 7, 2023 | 08:44 AM
joeking's Avatar
joeking
Cruise-In II Veteran
Cruise-In III Veteran
Wow 3 weeks at the dealership. Too bad they didn't order the parts and let you drive it. Good you have it back and in working order. I wonder why it needed two trim panels maybe they were damaged upon removal. It seems as if it only needed a sensor and a cylinder but good you have it back again.
Old Aug 8, 2023 | 11:11 AM
Bishop4142's Avatar
Bishop4142
This is why I keep a tarp in my trunk. You know the top will fail when it's about to rain
To Convertible top issue
