Another mouse issue.
Old Jul 9, 2023 | 07:53 AM
Richard Sawkins's Avatar
Richard Sawkins
Default Another mouse issue.
Was getting a dead critter smell and tracked it down to the small cubby in the rear corner opposite the battery location. On of the "family" did not survive and was decaying. In addition, there was a ton of bedding / nesting material which looks like it was stolen from under the carpets. To make matters worse, there was about 1/4" of water in the bottom of the cubby and I cannot find where it is coming from. So this weekend, I am looking around to check for any damaged or chewed wiring and checking under all of the carpeting for any signs of leaks. In my last 2016, I had to have the carpets replaced because they stink if they get wet since mold seems to love them. Ugh!
Old Jul 9, 2023 | 08:00 AM
Blackcherry20's Avatar
Blackcherry20
I Love My C7
Oh no!
Get some Cab Fresh and leave it on floor under your car. Someone else mentioned Irish Spring soap too.
Old Jul 9, 2023 | 08:54 AM
Maxpowers's Avatar
Maxpowers
This solved my mouse problem in my previous house garage.
Old Jul 9, 2023 | 01:19 PM
Mice can be a real PITA - hopefully the one you found is all there is. Set those traps and put in some deterrent items to keep them out of the car.
Old Jul 9, 2023 | 02:47 PM
ZO6LIFE's Avatar
ZO6LIFE
Peppermint. Works for me.
Old Jul 9, 2023 | 03:08 PM
dbirdhouse1's Avatar
dbirdhouse1
Default Professional followup
When I had rodent problems I spent the 150 bucks to hire a pest control company. Well worth it for not only good prevention but peace of mind (especially during colder times when cars sit and rodents are looking for warmer winter quarters)
Old Jul 10, 2023 | 06:31 AM
449er's Avatar
449er
CF Community Team
Forget the spearmint/ peppermint/ moth ball methods....just use some cheap spring traps baited with a dab of peanut butter....gets em every time!
Old Jul 10, 2023 | 06:41 AM
Swolejack's Avatar
Swolejack
My property abuts conservation land so I get a couple of the little bastids a week using good 'ol spring traps
Old Jul 10, 2023 | 06:43 AM
Swolejack's Avatar
Swolejack
Check if there are drain hoses for your a/c system, sometimes little tiny spiders build nests in them causing them to clog and
back up, soaking the carpets. Happens so much on Toyota/Lexus vehicles that we install special insecticide tips during the PDI
Old Jul 10, 2023 | 11:35 AM
DoubleG's Avatar
DoubleG
I am sooooo glad I don't have to deal with mice. It would drive me nuts knowing varmints are living in my car and slowly destroying it!
Old Jul 10, 2023 | 07:32 PM
jdaniels138's Avatar
jdaniels138
Veteran: Marine Corps
Since they like the cabin air filter material, I'm wondering if it's a good idea to remove it if you're not going to drive the car for a while. And reinstall it when you're ready to put it on the road again. I have a base stingray so it's really easy to remove/install.
/JD
Old Jul 10, 2023 | 07:41 PM
Blackcherry20
I Love My C7
/JD
may be a good idea. In addition to other stuff. We live in a very rural area. It’s a constant battle.
Old Jul 12, 2023 | 08:32 PM
St.Char's Avatar
St.Char
So far, for me too, winter storage.
Old Jul 13, 2023 | 02:29 PM
Walter Raulerson's Avatar
Walter Raulerson
I've posted before PEPPERMINT for a fast deterrent get the extract at the grocery store spread it around then look on Amazon they got a lot of stuff
To Another mouse issue.
