Window Seal squeaking?
Old Jul 13, 2023 | 01:17 PM
Rafo_Z51's Avatar
Rafo_Z51
Default Window Seal squeaking?
Hey Guys,
I have a 2017 z51 Coupe and in the last couple of weeks, I noticed that my windows started when going up or down. The rubber seal still looks good to me but I am no expert. Is there something I can do to it to fix it? Like som type of compound or solution? or do I have to replace the trim pieces? Just to clarify it is the rear rubber seal by the rear window.
Old Jul 13, 2023 | 02:04 PM
Maxpowers's Avatar
Maxpowers
Silicone spray. Spray it onto a cloth and apply.
Old Jul 13, 2023 | 02:25 PM
car2fast4you's Avatar
car2fast4you
If you have any dielectric silicone grease, that works very well too. Just apply a thin coat & wipe off the excess.
Old Jul 13, 2023 | 02:59 PM
Maxpowers's Avatar
Maxpowers
Ive tried GM dielectric grease. What I didnt like about it is its sticky. It would rub off on my clothes. Maybe a bad batch.
Old Jul 13, 2023 | 03:09 PM
car2fast4you
Never had a problem with it. It may be a bad idea, but I spread it on with my fingers, then wipe it off with an old towel if needed. It is a little sticky though.....but keeps the weatherstipping lubricated indefinitely.
Old Jul 13, 2023 | 03:11 PM
Travlee's Avatar
Travlee
mine started doing this after i fixed my door speaker, it looks like at the very back of the door panel i didnt get it in correctly. need to take it off this weekend and try to realign it
Old Jul 14, 2023 | 12:00 PM
Rafo_Z51's Avatar
Rafo_Z51
Would the wd-40 brand of Silicone spray work? and wouldn't the grease or spray make the window sticky?
Old Jul 14, 2023 | 12:08 PM
Travlee's Avatar
Travlee
then you would have wd40 all over the window i would think. mine only does it when it rains or after a wash, once its dry it stops
i plan to take my door panel off sunday and look at it again
Old Jul 14, 2023 | 01:03 PM
Gearhead Jim's Avatar
Gearhead Jim
St. Jude Donor '13
I've been using it for years because it works very well both to silence squeaks and protect the weatherstrip.
But it is gooey and will stain your clothes if it gets on them. I wipe off as much as I can and avoid rubbing against it.
To Window Seal squeaking?
