Simple Quick Jacks modification
Old Jul 17, 2023 | 11:15 AM
The Rainman's Avatar
The Rainman
Default Simple Quick Jacks modification
To make your Quick Jacks FAR easier to move around the garage floor:
The only thing I did differently from this guy's video was that I got my casters at Harbor Freight for $1.99 each. I also used long cable ties and criss crossed them so that they don't slip off. Really - the 3M tape and a cable tie holds these casters on quite well. If you place them in the right area, the casters are in the air when the jacks are in the UP position and don't support any weight of the car as shown below. They are only for moving the quick jacks around the floor and getting them into position.
Old Jul 17, 2023 | 01:54 PM
Catfish4818's Avatar
Catfish4818
I've gotta do that to mine...
Old Jul 17, 2023 | 04:23 PM
blueray16's Avatar
blueray16
I did this almost 2 years ago using double faced tape. Everything is still in place and the rollers are still working perfectly.
Absolutely no issues and no regrets.
Old Jul 18, 2023 | 07:37 AM
Tinkertech's Avatar
Tinkertech
I don't trust tape so I screwed mine on.
Old Jul 18, 2023 | 08:32 AM
jerkyboy's Avatar
jerkyboy
I added the casters from HF as well. I noticed the last time I used it one of the metal ***** from a caster was missing. Found it rolling around the back of my garage I'll need to either replace them or find better ones.
Old Jul 18, 2023 | 12:48 PM
Flattman's Avatar
Flattman
I did the same mod but put a quick spot weld where the screw holes are. Can always grind them off if I ever need to replace any of them.
Old Jul 18, 2023 | 12:58 PM
acroy's Avatar
acroy
Very clever however my car is too low it slightly snags the QJ's as it is
Old Jul 19, 2023 | 10:28 AM
Flame Red's Avatar
Flame Red
I love coming to this site and finding inexpensive ideas that are cheap and effective - without the Corvette Tax!
I had installed on my QJ 7000 a set of small swivel casters that was posted on a previous thread. But since they have to turn, they were a PITA so I was looking for a replacement.
Although there is a HF near me, I decided to get these even though they are plastic housing. I used a tie wrap and wrapped around the QJ arm and it through two holes in the caster just to keep the glue on tight. I would screw them on but it is hot here in the Florida Inferno and I am lazy.
It sure moves easily and does not stall like swivel caster did.
Thank you for the idea!
Just google "PlusRoc 8 Pack Self Adhesive Caster Wheels 1 Inch for Furniture, Load Capacity 28LBS Per WhePlusRoc 8 Pack Self Adhesive Caster Wheels 1 Inch for Furniture, Load Capacity 28LBS Per Wheel" if there is no HF near you or you are lazy and want something delivered to your door on the cheap.
To Simple Quick Jacks modification
