On fence for Range device.
Old Aug 24, 2023 | 06:05 PM
Red08's Avatar
Red08
I have had a range for the past two years. To me, all it does is keep the engine in V8 mode. As for shifting smoother, it didn't affect my C7,
Old Aug 24, 2023 | 09:01 PM
aklim's Avatar
aklim
Originally Posted by larrybee
I know. Beat a dead horse but need experience from range owners if this smooths out shifting and makes transmission stronger? Need a shove.
I don't think so. Not in my experience. All it does is fool the ECM into not running AFM because the readiness monitors are not in readiness state. Probably why you have to drive around for emissions testing with it off for a while. I sold it and got the Diablo I3. Regardless, your transmission is as strong as it is. Nothing can make it stronger besides tearing it down and beefing it up. The I3 can make it firmer and adjust the throttle tip in so you don't have to buy the Soler TB for the same effect, I imagine.
Old Aug 24, 2023 | 09:05 PM
aklim's Avatar
aklim
Originally Posted by BWF07
I simple drive my 2015 in the manual mode and it does two things. First it stops it from dropping to the 4 cyl. mode and it also stops any trans shutter.
Only a change of fluid can stop the transmission shudder, assuming it isn't too far gone. However, if can mask it so you don't feel it as much till too much water gets into the fluid. I suppose a new transmission would fix all the problems.
Frank4202's Avatar
Frank4202
I use one on my 17 Silverado. Love staying in V8 mode and no more weird sounds from the exhaust.
Old Aug 26, 2023 | 06:17 PM
1FINE99's Avatar
1FINE99
Cruise-In IV Veteran
Cruise-In V Veteran
I have had the range in my 2019 for 4 years . I was just wondering something though. I know you can put the car in "M" mode and it will not go in to 4cyl. So if you are in drive mode and get on the freeway I assume you could just put it in manual mode while going 70mph and it would stay in 8cyl ?
Old Aug 26, 2023 | 06:19 PM
aklim's Avatar
aklim
I wish I could assure you that it is that way. I believe it is but I have already had it programmed out but IIRC, you are right.
Old Aug 26, 2023 | 07:46 PM
Bills17n72's Avatar
Bills17n72
liks mine in my 2017, no issues!
Old Aug 26, 2023 | 07:55 PM
bassmobile's Avatar
bassmobile
No brainer. We didn’t buy Corvettes to drive a 4 cylinder. I can get that cheaper with a Honda Civic! I used one in my ‘16 Stingray and my current ‘19 Grand Sport
Old Aug 26, 2023 | 08:23 PM
aklim's Avatar
aklim
I bought my Corvette for several reasons. One of which is the power when I want. If the lifters were good, I don't care what it does when I don't need the power.
Old Aug 27, 2023 | 03:09 PM
astepup's Avatar
astepup
IIRC in one of the range device associated threads, one poster put it out there that because the device prohibits the designated lifters to do whatever they're designed to do it might be a good idea to unplug the device every so often, 3K miles or so (?) to allow the system to work as designed for proper lubrication and allow what was designed to move, move. I do that a few times a year for maybe 150 miles then at the next startup cycle I plug it back in.
Just an idea.
Old Aug 27, 2023 | 03:35 PM
aklim's Avatar
aklim
Just an idea.
Here is another idea if you are going to that. Leave the range off and let it lube whatever you want it to lube.
Old Aug 28, 2023 | 06:59 AM
Tinkertech's Avatar
Tinkertech
Strange thought, 99.9% of the M7 Corvettes never 'oil or exercise' the lifters and don't show any more unusual wear of the said lifters..................
Shouldn't they all be failing?
Huumm......
Old Aug 28, 2023 | 08:43 AM
  #33
eboggs_jkvl's Avatar
eboggs_jkvl
Moderator emeritus
2015 C7 of the Year Finalist
Ok, going on pure geezer logic, I'm guessing that if it moves, it gets oil. It might not get gas or spark but oil seems like a good thing to slosh around on any moving parts in the engine.
Active Fuel Management (AFM), which shuts down the LT1’s firing cylinders from eight to four by disabling the valves to the cylinders. When AFM initiates, the engine turns the 6.2L V8 into a 3.1L V4, shutting down cylinders 1, 4, 6 and 7, and firing only cylinders 8, 2, 5 and 3 in that order.
Otherwise, the complete firing order is 1, 8, 7, 2, 6, 5, 4, 3.
That's it, all I know. Going back for another cup of coffee.
Elmer
Old Aug 28, 2023 | 09:46 AM
  #34
AZRenegade's Avatar
AZRenegade
Huumm......
I agree. And just to add to that. If periodically "exercising" the AFM lifters is so critical, why isn't that addressed in the owner's manual somewhere in the manual transmission section?
Old Aug 29, 2023 | 11:40 AM
  #35
Black Rose-MD's Avatar
Black Rose-MD
Originally Posted by duckvett
The Range devise does nothing to smooth out shifting or make the transmission stronger. It eliminates AFM engagement, which in turn, helps to eliminate shudder. If you are feeling a shudder I highly recommend having the triple flush done. Then after doing the triple flush, buy a Range devise (buy direct from Range Technology, never a used one from Ebay) and enjoy the drive.
Exactly what I plan on doing... came back from a 10 drive to Bowling Green, started to feel the shudder and rumble strip motions ... '17 GS.(20K miles) purchased 8 months ago and this was the first long term road trip.. have a Range Finder (purchased from them not Amazon) now but going to get the triple flush and see how it goes.... I just want to prevent shifting to V4...
Old Aug 29, 2023 | 01:13 PM
  #36
squirrelchew's Avatar
squirrelchew
... if this smooths out shifting and makes transmission stronger?
It does neither of these things, nor does it claim to.
Old Aug 29, 2023 | 02:09 PM
  #37
aklim's Avatar
aklim
The problem is your fluid picked up too much moisture and if you leave it too long, it won't be good for the transmission, Range unit or not. All the Range unit does is mask it by stopping it from going into V4 mode. Your transmission is still spinning with wet fluid. Fluid it yesterday.
Old Aug 29, 2023 | 02:29 PM
  #38
aklim's Avatar
aklim
No but the mind is great at imagination.
