Miss Shift OOPS
Old Sep 9, 2023 | 08:51 PM
Ttrein76's Avatar
Ttrein76
Default Miss Shift OOPS
2017 M7 GS with 28k miles... Accidentally went from 3rd to 2nd while revving hard playing with no lift shift. Definitely hit 7k rpms and got out of it as soon as I could react.
Babied her home after that, but seemed to be running just fine.
Should i be worried? Guessing there isn't anything I can do but hope it didn't break or weaken anything.
#moneyshift
Todd
Old Sep 9, 2023 | 08:55 PM
96GS#007's Avatar
96GS#007
If you broke something you’d know it. It’s fine
Old Sep 9, 2023 | 09:12 PM
Lux's Avatar
Lux
Idk your ability to work on it yourself but pulling the valve cover to inspect the valve train wouldn't be a terrible idea but like he said above if you broke something you'd know. If it was just 7k rpm you're not significantly higher then redline and if it was momentary I'd bet it's fine.
Old Sep 9, 2023 | 11:34 PM
squirrelchew's Avatar
squirrelchew
if you hurt something it'll show up in the next 10k miles.
Old Sep 10, 2023 | 12:57 AM
This is from the 2017 Owner's Manual:
Caution
When downshifting, if more than
one gear is skipped, or the engine
is racing when the clutch pedal is
released, the engine, clutch,
driveshaft or transmission could
be damaged.
I think if something went wrong, you would know it. If it gives you peace of mind, either check things yourself or have a dealer/repair shop do a check.
Old Sep 10, 2023 | 04:12 AM
fuzzy03cls's Avatar
fuzzy03cls
You could develop a problem down the road. I had an over rev condition in an Acura.(past 10K) Seemed fine for several thousand miles, then the engine started to miss at idle.
7K isn't that high. Nothing you can do now. Just drive it.
Old Sep 10, 2023 | 08:07 AM
Zjoe6's Avatar
Zjoe6
Keep Rev Match on and it will rev up letting you know you're about to go into too low of a gear, and then you won't do it. Rev Match won't damage your engine. Learned this trick at Spring Mountain from the instructor in class. I haven't shifted into too low of a gear since.
Old Sep 10, 2023 | 08:47 AM
AnotherNorskie's Avatar
AnotherNorskie
What caused the miss ?
Old Sep 10, 2023 | 09:33 AM
dvilin's Avatar
dvilin
All good nothing to worry about 7k is nothing.
Old Sep 10, 2023 | 11:46 AM
Maxpowers's Avatar
Maxpowers
Hitting 7K once shouldnt have damaged anything.
Old Sep 10, 2023 | 10:00 PM
fuzzy03cls's Avatar
fuzzy03cls
Engine damage from the floated valves after they tore it down. Only stored code was the over rev code. After some push back they covered half the repair. I learned to not miss shifts again.
Old Sep 10, 2023 | 10:11 PM
devnull's Avatar
devnull
Scientific Negotiator
St. Jude Donor '07-'08-'10, '14
7k would not worry me, you're not vary far from what it redlines to and that's a fairly safe cutoff.
To Miss Shift OOPS
