Check Engine Light Afte Air Filter Replace
Old Oct 11, 2023 | 08:08 PM
thompstl1's Avatar
thompstl1
Default Check Engine Light After Air Filter Replacement
I replaced the air filter in my 2018 Z06 today. After starting it back up, the check engine light came on. I double checked the installation a couple of times and everything looks good. I did disconnect the MAF sensor while performing the replacement. I disconnected the battery in an attempt to reset the check engine light, but it didn't reset. The car runs just fine. I drove it about 20 miles and started/stopped it several times. Everything seems normal other than the check engine light.
Will the light reset itself eventually? Do I need to buy a code reader to reset it? If so, any recommendations? Any other suggestions?
Thanks!
Old Oct 11, 2023 | 08:41 PM
Dcasole's Avatar
Dcasole
Thanks!
You needed to disconnect the battery before disconnecting the MAF otherwise it will pop a code on startup
If you don't have a code reader , take it to any Advance auto , Auto Zone or O'Reilly they can clear code .... or just buy one off of Amazon....
Dave
Old Oct 11, 2023 | 09:09 PM
thompstl1's Avatar
thompstl1
Dave
Thank you!
Old Oct 12, 2023 | 12:00 AM
Yep, have an auto parts store clear the code.
Old Oct 12, 2023 | 12:22 AM
aklim's Avatar
aklim
Dave
What am I missing? It sounded like he got the light and then disconnected the battery to reset the code or did I misinterpret?
Old Oct 12, 2023 | 07:54 AM
joeking's Avatar
joeking
Cruise-In II Veteran
Cruise-In III Veteran
You need to disconnect the battery and wait 10 minutes. If you connect the battery right away you can get the check engine light to come on. The 10 minute wait should fix your problem. I did a new battery install and had that problem. I also did a K&N air filter but didn't have the problem so conditions do vary but if you disconnect the battery and wait 10 minutes your check engine light should come off. Otherwise several starts and restarts should make the check engine light come off.
Old Oct 12, 2023 | 08:33 AM
Dcasole's Avatar
Dcasole
You need to disconnect the battery FIRST , then disconnect the MAF . Install air filter , reconnect MAF and then battery
Op said he only disconnected battery after in an effort to clear code which if it's a true MAF code it WILL NOT clear without a scanner or x amount of starts without a fault
Dave
Old Oct 12, 2023 | 08:35 AM
Dcasole's Avatar
Dcasole
If u got a CEL changing the battery , something else is going on ..... as changing the battery should not set a error code ...
Disconnecting the battery for a MAF code will not clear it , see my comment above
Dave
Old Oct 12, 2023 | 09:25 AM
aklim's Avatar
aklim
Dave
Good to know.
Old Oct 12, 2023 | 10:00 AM
thompstl1's Avatar
thompstl1
Dave
I took my car to the Auto Store and they cleared the code. It's been fine since!
Thank everyone for the help!
Old Oct 14, 2023 | 12:34 AM
Avanti's Avatar
Avanti
If you're going to muck with it yourself and/or other contemporary cars, buy a cheapo code-reader (& resetter) from any parts store.
Old Oct 14, 2023 | 03:48 PM
ZMMMMM's Avatar
ZMMMMM
Did they tell you what code(s) were present before clearing them? You should rattle them off cuz that helps fellow owners identify, diagnosis, and, fix their issues. It also wins you karma points.
Karma will kick yer ***, OR, put you in first class” - ZMMMMM
Old Oct 14, 2023 | 04:11 PM
thompstl1's Avatar
thompstl1
The code was P2227, which is a code consistent with a problem in the air flow sensor near the air filter. The guy who cleared the code said it was common with air filter changes when the sensor was unplugged. I'll do it in a wiser way next time!
Everything has been fine since the code reset.
Old Oct 14, 2023 | 10:17 PM
eboggs_jkvl's Avatar
eboggs_jkvl
Moderator emeritus
2015 C7 of the Year Finalist
Ya made your MAF mad. It was an easy fix and you're on the road without a SES glowing on your dash.
Elmer
To Check Engine Light Afte Air Filter Replace
