Selling my C7 ZO6. It has a DSC Sport suspension controller computer. Want to return it to a stock alignment. I removed washers from the upper control arms bolts to help in increasing camber, but cant remember how many washers are under the front bolts and/or rear bolts? HELP?
The wide-body cars came from the factory with two shims behind the front upper control arm dog bones and one shim behind the rear upper control arm dogbones. This is different than the Stingray/Z51 which had two shims behind the rear upper control arm dog bones.
@Bill Dearborn - Per your comment regarding the Z51, does the Z51 have two shims in the front upper and two shims in the rear upper? Thanks always for your technical contributions.
