Hi Folks,
Done a search and not finding anything specific to what's happening with my 2015 Stingray.
From the drivers door window switch operates the passenger window as normal. Drivers window doesn't go up or down. It was working intermitently but not anymore. Windows index as normal?
Need a new switch? Does the whole door card need to be removed? Any videos?
C7's are sensitive to the battery output of the FOB and the car battery. An old battery in either may cause problems. I would check the age and output of both before I took the door panel off.
The fact it was intermittentl prior to stopping, does suggest a problem in the window system, a switch, connection, or motor. I just believe in the KISS Principle.
