Another broken valve spring Topic...
yesterday happened what we all do fear...
Was going home (around 35 mph in 4th gear) really relaxed, suddenly the car started shaking and misfiring and having a flashing CEL, immediately pulled on the side of the road, took my HP Tuner and did a diagnostic.
P0300 Random misfires, Rear Axle, Stabiltrack and IAT going crazy.
today opened up my valve cover and found what i was suspecting. 1 broken spring.
Luckily didn't dropped the valve in.
the car has been started after, except going in 7 Cyl, is running regular.
got to inspect everything by the way to search for some possible damages at rods, piston and so on.
My engine (second one) got a new LT1 crate 3 years ago, 35k Miles, regularly serviced and never abused, has yet installed from factory the Blue Springs (technically the less likely to fail, but yet happened).
Never ever have the eco mode enabled on the new engine.
The current engine has been bought new 3 years ago, with current 35k Miles.
The first one broke down for a wrong tune, non valves related issues.
..... thinking about installing a new set of springsDave
My ‘16 Stingray broke a spring at 60,000 miles and trashed the engine. My Corvette mechanic (former GM tech) installed a new LT1 crate motor and suggested replacing valve springs at 50,000 miles if using GM springs. Go with aftermarket performance springs and don’t worry about them.
By aftermarket you mean the ones with double spring? Those technictechnically prevent 100% the possibility of a valve drop?
I'll enjoy it while I can.
Dave
