battery charge
Old Nov 13, 2023 | 04:50 PM
teddycarnut's Avatar
teddycarnut
Default battery charge
How do you get to the battery to charge. On the 2017
Old Nov 13, 2023 | 04:59 PM
DrivesWithTwoFeet's Avatar
DrivesWithTwoFeet
Open hatch, carefully pull up rug on right rear side. Remove styrofoam tray.
Old Nov 13, 2023 | 06:50 PM
Avanti's Avatar
Avanti
Are you using a standard "charger" or a newer charger/maintainer? The plug on the side-panel above the battery is always "live" and is used by the latter devices.
Old Nov 13, 2023 | 11:59 PM
You can charge the battery using both of the methods above. I use a GM battery maintainer and just plug it into the outlet on the passenger side in the rear hatch.
Old Nov 14, 2023 | 08:49 AM
mdolandese's Avatar
mdolandese
When you lift the carpet be very careful you don’t rip it. It’s a pain in the *** because the carpet is under the trim piece, it takes patience. Also the plastic trim pieces scratch very easy
To battery charge
