Strong Fuel Vapors in Cabin
The last couple of times I drove mine, I smelt a faint gas odor inside the car. Suffering from long-Covid, it's hard to pinpoint the source. The other night my wife noticed it when we were driving together. There have been no signs of any fuel on the ground. I do have the special coverage for this known issue. I took it to my dealer on Monday morning. They have not been able to replicate the problem which is no surprise. Nor is the fact that the dealer didn't know anything about that particular TSB until I mentioned it to my advisor. I don't necessarily want them to find something, but I don't want them to miss it either.
Bayshore Vette (11-29-2023)
I too have the “special” warranty through GM for this issue. I’m just losing faith in my service department. My longtime advisor was “relieved of duty” recently. My new advisor hasn’t made a very good impression.
My ‘16 had this issue as well. First noticed gas smell while parked in the garage, then had a hard time filling. My dealer replaced the driver side tank under the GM 10 year extended warranty for this issue. Now no gas smell in the garage and have yet to try the fill as they returned it with a full tank.
It sounds like you need to find a different dealer, I drive by many to get to my preferred dealer service.
I too have the extended warranty but no issues. Be sure not to tell the dealer its a TSB. That may have had them being confused if that was said.
Go to the best Chevrolet where you live. Talk to the service manager and have his service department check the car and get a service receipt that documents the inspection. If they can't determine the source of the fumes, let them know you will be contacting GM (to request a regional service manager inspection) and filling out a NTSB hazard form. That usually gets their attention.
The following 4 users liked this post by SILENT BOB:
I had the same problem but in my 04 I think it’s the same as your special coverage is for, I’m told the cross over that was used in my 04 is the same used in the C7. It started out with just a fuel smell in cabin with no fuel leaks on ground but a few weeks later drips where showing up on Corvettes underside floor just below fuel door . Luckily by the time the fuel drips showed up I already had appointment for service two days later. No fuel in cabin but on underside of floor. Might verify that same cross over is used like I have been told. Here’s a few pictures !
The part where finger in pointing to is what I was told was bad. I don’t remember what the part name was.
The following 3 users liked this post by Borntorun04/17:
Received 19,795 Likes
'20-'21-'22-'23-'24
Fuel smell is nothing to mess with. I would seek out the best dealer you can find within a reasonable distance and have the car checked over again.
Where can I find this TSB? I have a 17 Stingray I recently parked in garage for winter and put on charger. Came into garage this am and strong gas smell in garage. I assume I have this problem as there is no sign of gas on floor under car.
Borntorun04/17 (12-02-2023)
thanks - I decided to uncover the car and fire it up. It idled fine for a bit then stumbled horribly and shutdown. I’m going to pull it out if garage and see if it drives. It’s. Crazy as it was driving perfect everything as normal. I parked it for winter and now this. I have to call dealer Monday.
The place where the drivers side fuel pump module cracks is below the very top of the fuel tanks - on the "flat" area where the fuel pump module sits. So, you typically only get the really strong fuel smell and sometimes drops on the floor, if the fuel tanks are full. Very similar, or maybe the same, issue that occurred on the later C6 models. GM's initial recommendation for the C6s', when the fuel pumps were on backorder, was to keep the fuel below 1/3 on fuel gauge, so that the cracked area in the primary fuel pump module on the drivers side tank, was not submerged in fuel. Unfortunately for my son, his C6 was just barely outside the "GM special extended coverage" for that known fuel pump module failure and it was $3500 to get it fixed by a local corvette specialty shop. All of the local Chevrolet dealers were quoting just north of $5000 to drop the rear cradle/exhaust/etc to replace this known defect. It is significantly cheaper if you have a manual tranny because a good mechanic can get their hands up in the space to disconnect the cross over tube without disassembling the car, whereas with the auto tranny, there is limited/no space to get your hands up there to disconnect the cross over tube - that is the primary reason they "need" to drop the rear cradle. The Chevrolet dealers just follow their recommended "book" procedures, so they do not charge any different whether you have the manual or auto tranny, except they make a ***load more profit doing a manual tranny car since they really don't completely disassemble the rear of the car, even though you get charged for that disassembly/reassembly, based on our experience with this problem.
thanks - I took her out for a ride to burn off about 1/8 tank gas as the tank was completely full. Hopefully it will not Leak until I can take it in.
If it is the "cracked fuel pump flange", you will need to burn off a lot more fuel to get the fuel level below the crack. You need to be more in the 2/3 to 3/4 empty range on the fuel gauge to get below that threshold based on how their 2 tank system works. The right tank gets completely emptied before the left tank starts to empty, as the fuel is transferred from the right tank to the left tank, until the right is empty - they both do not drop equally, together. It is absolutely amazing that GM would still have this problem on the C7s' at all after the bad karma it caused with the C6 models. Looking at the document cited above, it looks to be one of the same places that the C6 cracks regularly appeared. There were several places on the C6 left side fuel pump that cracked, this location is just one of them. In that document they say they "expect less than 5% will have this problem". What they really are counting on is that less than 5% will discover/encounter this problem within GM's extended service period while the other 95% who encounter/discover this problem will be outside that extended service period, so GM won't have to pay, just like the many C6 owners are still experiencing. Not saying 95% of the cars will have this problem, just the timing for those that are unlucky enough to encounter this problem. Disappointing, at best.
Thx - I’ll be burning off some more fuel when the weather clears up a bit - 40s and 50s and rain tomorrow. I looked on the GM site to see if “my VIN” was affected but never got a letter and nothing on the site for my car. I’m pretty confident I have the cracked flange problem. I have extended warranty so I should be covered hopefully. Not sure if I should bring to dealer now or wait till spring. If I drop the fuel level more and don’t smell gas I would think I’m fine. I am going to call dealer Monday either way.
Thanks all for your input!
