C7 Tops
Old Dec 17, 2023 | 08:44 AM
Texan79423's Avatar
Texan79423
Default C7 Tops
I had a C6 and I had to remove and treat the top seals every 4-5 months to stop the pops and creaking noises. Is that a common problem on C7's as well?
Old Dec 17, 2023 | 09:04 AM
joemessman's Avatar
joemessman
I have two C7s and neither one ever had pops and clicks. I do rub a light layer of GM dialectic grease to the seals about once a year. A real non detectable thin coat. I have had the Stingray for 8 years and the Z06 for almost 4 years and both have in excess of 100,000 miles on them.
Old Dec 17, 2023 | 11:10 AM
Ratboy's Avatar
Ratboy
My 2015 started creaking at about 40k miles. Didn't matter which roof - clear or carbon fiber. I tried the suggested fixes - o-rings on the rear pins, silicon grease and even adjusting the rear latch. Nothing worked. Then someone posted a fix from GM that included front replacement pins and latches, which did the trick. Its been about a year now and it hasn't come back. Fingers crossed. As I recall, the newer cars had the updated parts - 2017 up maybe?
Old Dec 17, 2023 | 11:15 AM
joemessman's Avatar
joemessman
2016 was the updated year.
Old Dec 17, 2023 | 12:04 PM
Gixxerman's Avatar
Gixxerman
Moderator
St. Jude Donor '18 thru '25
I don't use my clear top but both the painted carbon top and the raw carbon top do not make a sound. I do treat the rubber a few times a season with 303.. so far so good
Old Dec 17, 2023 | 02:26 PM
Texan79423's Avatar
Texan79423
Thanks for the input/ I have a new to me 2019 and the roof is solid as a rock.
Old Dec 18, 2023 | 12:27 AM
I have not had any such noises with my 2014, but I do treat the weatherstripping about once a year.
Old Dec 20, 2023 | 12:29 AM
Avanti's Avatar
Avanti
The tops are very sensitive to adjustments. I've found that with 4-tops across both my C5 and C7. That said, the factory setting for the rear hook are rather tighter as delivered than I expected to be necessary; that can be a clue if using different tops or you've bought a used car without any idea how it's been messed with over the years. Find an assured never messed with that doesn't make noises and check the rear adjustment; compare yours with it. Also, if you have the early C7 front pins noises can be worse. Finally (promise), the transparent top, which I greatly prefer on both my Vettes, are not as rigid as the solids (carbon fiber) which can contribute, as well. All the best.
Old Dec 20, 2023 | 07:21 AM
NashvilleGrandSport's Avatar
NashvilleGrandSport
Mine creak a little on my 2017, especially the clear top I bought pre-owned from a 2014 model. I understand there was a retrofit kit for larger or redesigned pins, but I did not do that.
Someone posted a solution that has worked great for me, using silicone surgical tubing. I removed the rubber washers off the two front pins, and cut the tubing the length of the pins (about an inch), and add the tubing for the two rear pins just for good measure. The tubing compresses into the holes really tightly, and eliminates the creaking in my case. I also keep the weatherstrip etc. conditioned. I replace the tubing whenever I remove or replace the roof(s).
Here's the tubing I used: https://www.ebay.com/itm/153190595484
Old Dec 20, 2023 | 07:04 PM
roadbike56's Avatar
roadbike56
St. Jude Donor '16-'17,'22,'24
Never had a noise from either top. Never treated the gaskets on either top.
To C7 Tops
