Alternator charging indication
Old Jan 10, 2024 | 03:56 PM
inspectorudy's Avatar
inspectorudy
Default Alternator charging indication
Today is a beautiful sunny day and 50 degrees so I decided to go for a top-down ride. I got the infamous click-click-click when I pressed the start button. I know what a low battery sounds like and I figured it might be down a little since the weather has been so bad here. I jumped it and it ran fine, however, the battery charge gauge showed about 15 volts and it never moved at all even at idle. No car I have ever owned did the charging voltage stay the same from idle to cruising rpm. Do any of you know if that charging gauge should vary with rpm?
Old Jan 10, 2024 | 08:53 PM
Dcasole's Avatar
Dcasole
C7 charging systems are controlled by the ECM , and voltages will vary from a low of 12.6 to 15.4 . An alternator WILL not charge back to normal levels a dead battery, hence the reason why it was showing 15 volts. The alternator will eventually fail trying to maintain this level of charging . On the older style alternators trying to charge a really low battery would result in a fried Diode Trio , a trickle charger might bring it back to close to full charge but struggles because of increased resistance the closer it gets to full charge . . You need a real charger and slowly charge it back at a rate of 4 to 8 amps . HARBOR FREIGHT sells an inexpensive 2 8 15 am computer controlled charge that works great
Dave
Old Jan 10, 2024 | 10:14 PM
CPB's Avatar
CPB
What's the SOH on the battery?
Old Jan 11, 2024 | 12:39 AM
inspectorudy
Thanks Dave, I have it on a trickle charge now after jumping it ran fine. I'll see what it does after a full day's charging.
Old Jan 11, 2024 | 11:38 AM
DoubleG's Avatar
DoubleG
I happened to look at my gauge a few days ago and saw it said 15V at freeway speeds. It did drop when at idle, but I don't remember to what, but it was a more normal level
To Alternator charging indication
