Pedal Commander - Current Users Question
Old Mar 6, 2024 | 11:14 AM
Itsmebryan's Avatar
Itsmebryan
Originally Posted by mxw128
So figured I'd reply since I didn't see too many current PC owner's. I have a 2018 GrandSport M7 and I got one used (guy sold his Chevy SS) and have been using it since the Oct/Nov timeframe. No issues yet, and it's performing as advertised. I use the Sport +1 or 2 settings and it does help with smoothing out my throttle application when shifting. I found that the OEM throttle response was little long for my taste and right foot. The only thing I don't really care for (and it's not specific to the PC) is that having to pull up an App every time i get into the car is a bit of hassle.. I Know, 1st world problems, it's just a little annoying. Part of it could be that my app is in my Auto folder (no room on the home screen), so I have to navigate a screen or two back .. a self inflicted nuisance... I don't need the app up except to verify that the PC is indeed in the mode I want it to be. I had a Sprint Throttle Controller on my previous C6 GrandSport which was also a manual and the PC provides the same benefits. So just another perspective...
I thought it saved your settings when you turned the car off like the other pedal controllers. I can see how that would be annoying.
Old Mar 8, 2024 | 03:51 PM
mxw128's Avatar
mxw128
You're right, It does. I just want to be able to verify it ( it reverted to city once for some reason) and try different settings. I'm still "new" to using it so sure once I get accustomed to the setting and find one I really like I won't need the app.
Old Mar 12, 2024 | 12:46 PM
cdgrafix's Avatar
cdgrafix
Originally Posted by cdgrafix
Because I'm impatient, I plugged the pedal commander in on sat cause i wanted to see how well it work. Well, i got a flash of lights across the top of the controller and then nothing else.
Banks Pedal Monster is on the way.
Quick update. Installed the Banks Pedal Monster and i must say I'm very impressed w/ it so far. Had to update the firmware when first plugged in but other then a few minutes wait to time to download, everything working like it is suppose to and i really like the reverse feature that switches the pedal sensitivity back to normal while backing up.
