I see all sorts of posts on the fluid for the rear diff fluid i.e.10-4034 but then some of the posts say if it has the electronic rear dif i.e Z51 you should use AT fluid 10-9394
Can we get this cleared up Thanks for the help
p.s. I have a 2016 z51
The portion of the differential where the gears are located uses 75W90 gear oil. Some people like the GM stuff. I like RedLine. Others like Mobil, Valvoline, Royal Purple, Amsoil, or a variety of others. Pick one you like.
Z51 equipped cars (as well as the GS, Z06, and ZR1) have the electronic Limited Slip Differential....eLSD. Think of this as an add-on system to the basic differential. It is filled with ATF. You do NOT have to service this. The ATF is in there for hydraulic pressure against the pistons. It is a closed system. If you chose to try and service this system, you'll need the GM tools to bleed it properly. Unless you're installing a new or used unit that was disconnected from the eLSD pump, leave it alone.
In the 2014 I had the rear lube needed to have a friction additive. The GM fluid already had it but other brands needed to have it added. I always used the GM and never had an issue. I'm not sure if it's the same for a C8 but I expect it is.
The mechanical LSD that non Z51, Z06, GS, ZR1 cars are equipped with requires the friction modifier. The eLSD doesn't require friction modifiers since it doesn't have any clutches inside the diff.
Awesome response and looks spot on to me I was about to screw up and open the system and put the wrong fluid in it since it is a different system
Thanks much
Bill
I have a 2019 Grand Sport (A8), 13,500 miles. Would you recommend changing the differential fluid?
",,, 2019 Grand Sport (A8), 13,500 miles. Would you recommend changing the differential fluid?" No, just check the fluid level and top-off to bottom of the check hole. Many required additional fluid when new to meet this GM method, though the differential manufacture CEO said on a public vid they all shipped with the correct amount. My 2018 St'ray took just over 8oz. All the best.
There are all kinds of confusing replies concerning eLSD fluids in C7 diff. I understand that the pump for the hydro-static portion of the unit uses ATF -6. My questions are; the clutch pack appears to be a wet pack. Is it running in the differential gear oil? From what I can find online, it appears that it is and the reference to ATF-6 is only used in the pump and is not part of the actual lube on the clutches. That makes me think that friction modifier is required as it would be in a conventional LSD. If so, not withstanding the 2014 low fill TSB, all the comments about what appears to be fine metallic particulates in the gear lube would be normal clutch material being shed.
Are there any eLSD experts that can verify or deny the actual operation of the lubrication of the differential?
I have seen many concerns about poor quality of the diff assembly, but the photos of the gear lube don't appear much different from any used lubricant from conventional LSDs that use clutch packs. (Again, not including Torsen type diffs).
Reason: Prior incomplete message
