Considering a C7
Old Feb 11, 2024 | 12:21 PM
John 511's Avatar
John 511
Default Considering a C7
What year is the most trouble free?
Old Feb 11, 2024 | 12:57 PM
Shokwav's Avatar
Shokwav
Buy the newest one you can find in the best condition with the lowest miles. At least that’s what I would do. The newer the year the more improvements it will have had from gm.
Old Feb 11, 2024 | 12:58 PM
dbirdhouse1's Avatar
dbirdhouse1
Believe it or not the first year/2014 has not only been one of the most trouble free but one of the most trouble free year intros of all time. From there the Corvette rather than the GS or Z06 has caused fewer problems because it lacks those areas where the other two caused some statistical grief; cracking wheels, transmission shuddering (8 speed auto) and overheating (on the track with the Z06). But even these are still statistically rare and the condition of the individual ones you look at will be a far greater variable. Good luck
Old Feb 11, 2024 | 03:40 PM
Squeaky Wheel's Avatar
Squeaky Wheel
If you want an automatic, and don’t care about a front camera or Apple CarPlay or Android Auto, I’d look for a nice 2014 with the 2LT trim. And if you want a few more track oriented options, a Z51. Makes for a pretty nice and reliable package at a reasonable price IMO. I may be a little biased though since that’s what I bought after selling a 2016 3LT coupe with the A8 transmission.
Old Feb 11, 2024 | 04:44 PM
fuzzy03cls's Avatar
fuzzy03cls
That is what I did. 2019 with 8500 miles
Old Feb 11, 2024 | 07:43 PM
roadbike56's Avatar
roadbike56
St. Jude Donor '16-'17,'22,'24
When it comes to the C7, there's no year to avoid. Pick a Corvette C7 you really like then come back to this forum and ask for input about that car.
Old Feb 11, 2024 | 09:33 PM
Raidercop's Avatar
Raidercop
I went for a 2019 Z51 with a M7. Seems a lot of issues with the other yrs were addressed by GM. I even went for a 3LT and GM made corrections to dash.
Old Feb 12, 2024 | 05:20 AM
corvettezman's Avatar
corvettezman
St. Jude Donor '11-'12-'13, '15, '16-'17-'18-'19
The dash was still an issue in 2019 3LTs. It is an issue with C8s as well. They have added staples I think but the issue is still there.
You are just one of the lucky ones, so far.
Old Feb 12, 2024 | 06:50 AM
Raidercop's Avatar
Raidercop
yes mine has the added staples and "new" glue
Old Feb 12, 2024 | 08:04 AM
joeking's Avatar
joeking
Cruise-In II Veteran
Cruise-In III Veteran
The 2014 is known to have the most trouble free automatic trans.
Old Feb 12, 2024 | 08:20 AM
Jeff T.'s Avatar
Jeff T.
St. Jude Donor '13 thru '26
Understand what options are important to you. For example, I use Android Auto, 14/15 did not come with AA...
Old Feb 12, 2024 | 08:30 AM
boraxman's Avatar
boraxman
Some early 16's didn't have it either.
Old Feb 12, 2024 | 09:46 AM
Rabbi's Avatar
Rabbi
Mine developed the shudder, it goes across all their models.
Old Feb 12, 2024 | 11:24 AM
Squeaky Wheel
Is yours a 2014 with the A6? First I’ve heard of that with the A6. Have you been able to eliminate it? If so, what was the remedy? Triple flush of the tranny fluid with the new improved version?
Anyone else had a shudder problem with the A6?
Old Feb 12, 2024 | 12:19 PM
I have not had any problems with transmission shudder on my 2014 A6. I will agree that the first year C7 has been a very reliable car with just a few exceptions. Mine had an infotainment screen that needed replacing and recently a belt tensioner, but that is it. If you want newer, just be sure to have it thoroughly checked over by a good Vette tech, as you should do with any year that you are considering. Good luck - the C7 is a very good car and a blast to drive.
Old Feb 12, 2024 | 12:23 PM
dvilin's Avatar
dvilin
2014 is the one labeled as the most trouble free C7.
Old Feb 12, 2024 | 12:36 PM
AnotherNorskie's Avatar
AnotherNorskie
It's not so much the 'years' as it is which options it came with. If you eliminate some of the more troublesome options you'll have the most reliable one, regardless of year.
  • 3LT's you risk dash delamination (narrows it down to 1LT or 2LT)
  • Automatics spend more time in AFM and increase the risk of lifter and torque tube failure (narrows it down to the M7's)
  • If you must go auto, the A6 ('14 and '15) have the least issues, but it seems the A8's issues are solved with a triple-flush.
  • GS and Z06 crack wheels.
I would also suggest getting one that has enough miles on it to sus out any issues while under warranty. You don't want something with 2k miles and years out of warranty.
Thus, a non-3LT Stingray with three pedals will be the most reliable.
To Considering a C7
Old Feb 12, 2024 | 12:47 PM
Squeaky Wheel
I agree, but with a slight correction. Only the 2014 has the automatic A6 transmission.
Old Feb 12, 2024 | 12:49 PM
orca1946's Avatar
orca1946
Did you get the 2019?
Old Feb 12, 2024 | 12:51 PM
Bayshore Vette's Avatar
Bayshore Vette
@C7GSM7VERT
2019 2LT seems to be the most sorted out of the C7s. GS is the least expensive wide bodied Corvette, if that is your thing. Getting rid of the OEM wheels (GS/Z06) is the price of admission. M7 avoids AFM, if that is your thing as well.
