Paddle Shifting Help - Noob
Old Feb 12, 2024 | 09:43 AM
jetplane12's Avatar
jetplane12
2nd Gear
Default Paddle Shifting Help - Noob
Hello Corvette Forum,
Recently acquired 2017 C7 GS Automatic (Admiral Blue) During automatic driving, noticed a jerkiness in mid to high gears. After research, this is due to the v4/v8 active fuel management system. What a joke that is....
Did further research, and if the car was kept in manual mode, it would stay in v8 mode. Seems like a simple fix. Never driven a manual before.
The upshifting I understand, the downshifting is where I'm struggling. When braking, the car automatically downshifts, is this normal? I don't mind this one bit..
the next thing I'm struggling with. What are the proper methods for downshifting and accelerating? Can 2 or three gears be dropped to make a pull? Gas or no gas, just need some assistance and clarification, please.
Old Feb 12, 2024 | 10:03 AM
Carvin's Avatar
Carvin
St. Jude Donor '15-'16
Dropping from V8 to V4 should be seamless. Sounds like you have problems. There are many threads here about A8 tranny problems.
The automatic downshifting is normal. You can hold the down paddle and it will drop several gears quickly.
Old Feb 12, 2024 | 10:05 AM
joekd's Avatar
joekd
Buy a Range AFM disabler, plug it into OBD port, never see V4 mode again
Have had mine on 2 cars so far
Old Feb 12, 2024 | 10:57 AM
jetplane12's Avatar
jetplane12
2nd Gear
it's seamless from v8-v4. it's not going from v4 to v8. something to do with the torque.
Old Feb 12, 2024 | 11:52 AM
Vette Jockey's Avatar
Vette Jockey
Roadster Madness. 😠
St. Jude Donor '13, '20-'21
Something, is wrong. Do you know if the car has had the Tranny Tripple Flush done? The only way I know mine is going from 4 to 8 or 8 to 4, is when the gauge tells me it did.
As for Paddle Shifting, keep the "R's" up and you will have a seamless upshift.
Down Shifting, it depends on what I am doing. If I am on a mountain road, I am keeping the "R's" up, I just down shift one gear. If I am on the Freeway cruising and want to pass, I just down shift three gears in quick succesion. That seems to be the "Sweet Spot" for me.
Old Feb 12, 2024 | 11:53 AM
BWF07's Avatar
BWF07
St. Jude Donor '11
Oldtimer
If what you feel is like a short run over rumble strips, it is the transmission shutter. That can be fixed with what is known as the Triple Flush. There is a service bulletin on that issue.
Old Feb 19, 2024 | 10:56 AM
FLX C7's Avatar
FLX C7
Before I bought my 2014 C7, I had a Ferrari V12 with a TH400 transmission. I learned to shift it with the gas pedal. With the A6 in the Vette I had to teach my foot to mind his own business, the tranny is far smarter! Just keep constant right foot or brake as needed and let the tranny do the rest.
Ken
Old Feb 19, 2024 | 12:18 PM
inspectorudy's Avatar
inspectorudy
I have a 2016 Stingray that shifts back and forth from V4 to V8 with no noticeable inputs. Where you may get some is when you are in V4 and try to accelerate quickly. This is why I posted my experience with the paddles when in V4 and accelerating. I simply downshift before I hit the gas while in V4 mode and there is no jerking or anything else. As mentioned above, if you are getting a stumble or shudder when transitioning you probably need the triple flush. A lot of people using paddles let the transmission do the downshifting for them. The only times when that does not make sense is approaching a sharp curve or hill that the transmission cannot see but you can.
Old Feb 19, 2024 | 06:43 PM
IA-SteveB's Avatar
IA-SteveB
I notice mine when the exhaust gets a bit quieter when settling into cruising speed and AFM closes. I probably notice it more because I drive with NPP valves open. I appreciate linear exhaust tones and AFM kills it.
To Paddle Shifting Help - Noob
