Playing with V4/V8
Old Feb 14, 2024 | 10:50 AM
inspectorudy's Avatar
inspectorudy
Default Playing with V4/V8
I have been experimenting with driving in "D" and watching the V4 mode pop up and I have found that if I don't try to accelerate in V4, I don't get any lag or disappointing acceleration. What seems to work well is to downshift with the paddle while in V4 mode just before you want to accelerate or go up a hill. This way the engine and transmission are in a stable condition with no load on the engine or torque converter. Then when you downshift, the tranny goes to "M" and the engine goes to V8 with no load on either the engine or the torque converter. Think of the paddle as a passing gear while in V4 mode and it works out with no noticeable hesitation or droop. Then after you have passed or climbed the hill the tranny will automatically go back into "D" and the V4 mode will come back on if the road is flat. I think most of the torque converter issues come from trying to accelerate while in V4 mode. Give it a try and let me know what you think.
Old Feb 14, 2024 | 11:30 AM
Flame Red's Avatar
Flame Red
No disrespect. Sick of the Gooberment BS.
Corvettes don't need no stinkin' V4 mode. Either get a Range device, or turn off the AFM with a tune.
Old Feb 14, 2024 | 01:13 PM
Punisher44's Avatar
Punisher44
What I think is V4 does way more harm then good. It causes drive train issues has a chance of destroying your motor when going from v8 to v4 and back again. For me from day one I've had a range device.
Old Feb 14, 2024 | 02:32 PM
I have the Range AFM Eliminator plugged in and do not have to worry about V4 mode. The small penalty on gas mileage is worth it to me.
Old Feb 14, 2024 | 02:48 PM
Woodson's Avatar
Woodson
Never used V4, never will. It's pointless and asking for trouble.
Old Feb 14, 2024 | 03:35 PM
Keith Richards's Avatar
Keith Richards
If the Range device was not available and a person could not "tune" it out I would have sold my 2019 GS weeks after I bought it new. No place for a V4 for me with this type of car.
Old Feb 14, 2024 | 05:23 PM
Frankie2blue's Avatar
Frankie2blue
I have always used a Range in mine and never used the V4, which I also think is stupid. I do however get a little nervous when I hear some claiming that keeping it shut off all the time is inviting disaster also. I already went through all the dropped valve stress and worry when I owned the C6 Z06, and I don’t need it all over again.
Old Feb 14, 2024 | 06:48 PM
Bill Dearborn's Avatar
Bill Dearborn
I think GM's mistake was disengaging the torque converter clutch during the V4/V8/V4 change. The engine changes modes a lot when driving at constant speeds on a somewhat level road. Every time the road has an almost imperceptible dip the engine switches to V4 mode and as soon as the dip starts to go away it switches to V8 mode. US roads even very smooth ones are filled with plenty of imperceptible dips that cause all of these mode changes. Each time this happens the TCC is disengaged and engaged causing wear on the TCC. With the M7 cars Eco mode is only operable when the dial is turned to Eco and doesn't disengage anything since there is no TCC thus the engine is always directly connected to the transmission and the driver never feels the changeover. With the M7 there is no change in rpm as there is when the TCC disengages and engages so the only way to know when the change happens is when the exhaust closes (V4) and when it opens (V8), when the exhaust is set in Stealth Mode you can't hear anything either.
Bill
Old Feb 15, 2024 | 07:13 AM
Tinkertech's Avatar
Tinkertech
The A8 TCC is always in a 'slipping' mode ( engaging / disengages ) usually around 10%. It is never locked up as in the past at 100%.
When you enter V4 mode the TC does this 'dance' even more ( higher % ) to help isolate the V4 engine vibrations, ie: even more wear and tear.
Do you think that GM went to this 'dance' and a steel torque tube housing instead of using the previous aluminum one just for fun and giggles? No, it was due to excessive vibration from the V4 unbalanced mode of operation.
Old Feb 15, 2024 | 07:37 AM
ren80's Avatar
ren80
I have a 2014 m7 with 22k miles for about a year. I have never engaged eco mode to actuate the v4. I don't know if previous owner ever had either. Is there any perceived problem in never actuating the eco mode? I'm afraid if I did actuate it accidently something will malfunction. Is there any benefit to letting it run in eco once in a while?
Old Feb 15, 2024 | 09:40 AM
Carvin's Avatar
Carvin
St. Jude Donor '15-'16
I don't believe ECO mode automatically kicks you down to V4. Bill?
Old Feb 15, 2024 | 03:15 PM
inspectorudy
I understand your reluctance to use the V4 mode but I have owned a GMC and Silverado trucks with it and never had an issue. Like I said, I usually use manual so I don't run in V4 mode but was only trying to see if there was a way to not try to load the tranny while in V4 mode. I believe I accomplished my aim and also I did not see any transitioning from V4 to V8 and back on normal roads. While in V4, anytime I wanted to accelerate I just tapped the downshift paddle and the car instantly went into V8 mode and then I accelerated. I am a believer in keeping any system in my car operational and exercising the V4 mode is one of them. Obviously, this system was designed for GM's mpg issue and not the owners of their cars/trucks, but it is still part of our cars and if not maintained may become a headache later. IMHO
Old Feb 16, 2024 | 01:04 PM
orca1946's Avatar
orca1946
So Should use v4 once in a while to keep parts moving?
Old Feb 16, 2024 | 10:36 PM
C5FORFUN2's Avatar
C5FORFUN2
I do. On my GS the change is so seamless I thought it had been tuned out, but when I changed the display that shows V8 V4 it is working, just not real noticeable and I have the NPP open.
Old Feb 16, 2024 | 10:54 PM
sjw91's Avatar
sjw91
With the M7, it will go into V4 only if you're in ECO. With the automatics, it will go into V4 in any mode.
Old Feb 19, 2024 | 07:45 AM
Adam9066's Avatar
Adam9066
I use it on road trips. But I have had a few GM vehicles with AFM never had an issue with any of them. When I got my first truck I swore it was gonna blow up from all the stuff I read on the net and it never did. That said the transition on the GM trucks and SUVs is a lot harsher then it is on the vette. Not sure it's cause of the weight or the tune.
That said I have built and owned many cars that people said wouldn't hold up. I still have a stock 4l60E behind my 481hp lt1 in my 95 camaro and it has over 160k mile on it with a 3600 stall converter.
I think a lot of people abuse their stuff and find a reason to blame someone else for the failure. Obviously the lifters and other components to have a higher level of failure then older setups and some vehicles are just problem plauged the day they leave the factory. Been there got the T-shirt wore it out. But I do belive more failures happen from abuse whether it's driving hard or not doing proper service to the vehicles or trying to cheap out while doing it.
To Playing with V4/V8
