I have a 2019 GS and I get notices when TSBs are released for 2019 Corvettes. However, I can't open any of them.
Where can you find and read TSBs published for your C7 ?
does the dealer perform the tsb at no charge to customer?
Depends on the TSB. For example, safety related, the answer is almost always yes. New Mobil1 trans fluid and triple flush, if you're out of b2b and powertrain warranty, then you're SOL. Paying for that yourself, shudder or no shudder.
You can get a subscription to Alldata or Mitchell for a month, year, or multiple year and read all TSB’s there.
TSB are only covered at no cost as long as you are under B2B or power train warranty time frames. They also are not just blanketly applied to the vehicle, you have to bring the vehicle in with a description of an issue that is related to the TSB.
