Replacing backup camera?
Old Mar 20, 2024 | 06:55 PM
Casper001's Avatar
Casper001
Default Replacing backup camera?
Has anyone found a better backup camera then the OEM one? I have a 2019 Stingray and the backup camera is horrible when it is very dark outside. Yes, I know we all used to backup without cameras and with the quality of this one it is barely worth using in the dark.
Old Mar 20, 2024 | 10:10 PM
fuzzy03cls's Avatar
fuzzy03cls
It's not so much the camera but lack of lighting at night. The backup lights are not very bright, are sunk into the tail light, & positioned high compared to the camera.
Old Mar 20, 2024 | 11:56 PM
aklim's Avatar
aklim
Question. Is it possible that the camera is not as good as it used to be?
True but we also used not to have toilets and used the outhouse. Toilet paper wasn't invented till 1857. I don't want to go back either.
Maybe not but it is fantastic in the day or dusk at least so it does have some use. Have you tried using some sort of headlight treatment, basically a fine polish to remove any scuffs or oxidation to make it clearer?
Old Apr 19, 2024 | 01:37 PM
Casper001's Avatar
Casper001
I think part of the problem also is that exhaust fumes/smoke goes up directly in front of the backup camera; not sure how much that affects the camera but it certainly can't help.
Old Apr 19, 2024 | 01:39 PM
Casper001's Avatar
Casper001
That was definitely my issue on a SUV I used to have so I had a 4-wheel drive shop install a small LED light kit connected to a rocker switch. That way I could turn on the extra lights when backing up at night. Maybe I need to consider something similar again (the light kit I used before were very small, not like large off-road light kits you see on trucks).
Old Apr 19, 2024 | 02:18 PM
Flame Red's Avatar
Flame Red
A while back there were several threads on how to replace the earlier year C7 rear cameras with the later C7 rear camera. So I assume 2019's came with the best GM had to offer?
Old Apr 19, 2024 | 02:37 PM
Casper001's Avatar
Casper001
Maybe so, but that definitely does not say much. I had a much better camera in an old 2004 Acura I used to have.
Old Apr 19, 2024 | 06:31 PM
fuzzy03cls's Avatar
fuzzy03cls
I have a 2019. Still sucks compared to others.
Old Apr 19, 2024 | 06:40 PM
BluRace's Avatar
BluRace
has anyone found an aftermarket camera to replace the weak GM version?
Old Apr 19, 2024 | 09:00 PM
Kingman99's Avatar
Kingman99
My Subaru has a better camera
Old Apr 19, 2024 | 09:22 PM
In for some recommendations, but so far I do not have any major complaints about the rear camera on my 2014.
Old Apr 19, 2024 | 09:32 PM
sjw91's Avatar
sjw91
Can anyone verify it's actually the camera and not the resolution of the screen?
To Replacing backup camera?
