To disable a 2017 GS 8A;
Is pulling the Engine Compartment Fuse Box Fuse 31 Fuel Pump Control Module (only) sufficient to disable the vehicle,
or does the Rear Fuse Box Fuse 30 Fuel Pump Power Module need to be pulled as well? - Pull one or pull both??
OR, is there a different Fuse to pull in order to disable the vehicle?
