C7 Convertible - CB Antenna?
Hi guys,
Need some advice as to a decent CB Antenna for my 2014 C7 Convertible. I did a forum search which gave me a ton of posts, but none that I could find that were actually about CB Antennas. I lead a lot of club drives and our standard GMRS pocket sized radios just aren't reaching to the back of the line. I've already tried and rejected the BTech GMRS Pro and so now, we're looking at CB's. I've got a couple of different radios....just looking for a decent antenna setup. I found this - but from the sound of it, they're no longer available. https://www.c6performance.net/catalo...-p-504867.html
I'm interested in seeing what ya'll know about the best way to hook up a good antenna that can be removed without a big hassle.
Thanks in advance
Thanks in advance
Artarmy (04-20-2024)
I did not know people (besides truckers) were still using CB's. when we have a group of Corvettes, we simple use the cell phones.
Must be nice to be able to cruise areas of the country that have complete cell coverage. The North Georgia mountains where we go to play is not one of those areas - hence the radios. Does anyone have any actual information on CB antennas?
calvins (04-19-2024)
You might contact Walcott Radio. They are a premier CB shop that has seen it all after many years of business in the field. Truckers rely on them and they are extremely knowledgeable.
walcottradio.com.
They hooked me up with a proper antenna and a mount. I had to do a bit of adapting but pretty minor as it was a somewhat universal type mount. I'm pretty sure they can help you out.
walcottradio.com.
The Rainman (04-19-2024)
walcottradio.com.
walcottradio.com.
Oldtimer
The main problem you'll probably face is that the antenna's work on the premise of having a good ground plane and our cars are fiberglass, as you're well aware of. You can find "loaded" antennae but I've no idea how you'd mount it to the Vette. GL The other option, if you travel as a group, would be hand held FRS radios. They're only legal to two watts so the range would be very limited, especially in the mountains.
Firestick (brand name) antennas are probably the best for a Corvette as they are used a lot with fiberglass RV's that also lack a ground plane. The problem will be with mounting and getting the antenna above the rear of the car. Weight and length of the antenna (due to not needing a ground plane vehicle) plays into needing a sturdy mount.
The RV's will typically use a side mount that requires drilling two holes, so that option is out.
Here's a good mount that could be adapted for use on a custom license plate bracket if you can get one made:
https://www.rightchannelradios.com/p...b-mirror-mount
An option could be this 5W GMRS radio (in pre-order for a May release) that was tested in the Rockies and touts a 2 to 8 mile range in the mountains. GMRS licenses would be required. GMRS can use a repeater if available and can also use an external antenna.
https://rockytalkie.com/products/5-watt-radio
A good explanation of 2W FRS and 5W GMRS vs terrain:
Relaying front to back and back to front could extend the distance for FRS / GMRS / CB but would require some discipline/cooperation from your cluster of vehicles.
Another option, but very expensive, would be to use satellite phones (like Iridium).
My club already uses the cheap FRS/GMRS radios that work - ok - for short distances. I recently tested some Baofeng (B-Tech) 5 watt GMRS radios that were HIGHLY disappointing. Aside from poor sound quality, the features they advertised barely worked sometimes and the range was maybe 1/4 mile better than the Midland's we had been using. We've been playing around with ideas that will work in our area and CB's usually have decent sound quality and reasonable reach. Hence why we're wanting to test this out. Relaying front to back is frustrating and dependent on too many variables.
Ha...satellite phones....yeah, that MIGHT work, but we drive Corvettes, not Ferrari's. I don't have that kind of money.
So, if the CB option doesn't work out all that well - we're also looking at this: https://rapidradios.com/products/rap...-walkie-talkie
It runs off the cell networks - apparently ALL of them. I've got AT&T and don't have service a lot of time in the mountains, but apparently these things operate off of any cell carrier - from what I gather - much like the old Nextel's did. You can set up a group of up to 200 people. I'm intrigued, but after the first year, it's a yearly cost of $50 per radio which is bound to go up at some point.
I am hopeful that this CB radio scenario will fill our needs and we can just go that route.
Received 2,067 Likes
St. Jude Donor '13
For our first 15 years in the local Corvette club, we used a hardmounted CB with a L-shaped bracket that is held in place by the rear license plate and a Firestik antenna about 18" tall.
That worked fairly well, highway range about 1/2 mile in "average" conditions. Somewhat directional, range to the rear was moderately greater than to the front.
About 5 years ago our club switched to GMRS.
I've been using a Midland hand-held for that. It's range is about equal to the CB with a hardmounted antenna.
With either system, range is tremendously effected by local conditions (direction, cars, terrain, etc) and antenna choice- longer is better, higher is better. If comparing range of different systems, you need to keep everything else constant.
I'm not really satisfied with the GMRS handheld, some day I'll switch to a hardmounted GMRS with a good hardmounted antenna. One member of our club had a similar system mounted on the wing of his C7 ZR1, his range was outstanding but it was expensive, ugly, and took a lot of effort to install.
Best of luck to you.
Baofeng 5 watt GMRS
Moderator/Tech Contributor
Location: Jacksonville Florida BWO Dayton, Cincinnati, Bloomsbury NJ, Cincinnati
Received 3,838 Likes
2015 C7 of the Year Finalist
https://www.ruggedradios.com/
https://www.pciraceradios.com/
These are the radios used in the Baja 1000. Either one can get you set up with radios to reach the back of your club cruise.
