Missing emergency drivers door release
So in doing some other work on the car I noticed my emergency door pull went MIA. I pulled back the carpet where the hole is and I don't see the mechanism rod anywhere. Anyone have any idea where it might be hiding. I'm assuming it's a rigid rod assembly and not a braided wire.
any guidance would be appreciated.
Missing drivers door release cable 2018 post
Emergency Door Open cable.
When I bought my used LRGM Stingray I noticed that the emergency door cable was not visible and had slipped behind the trim panel as you described. I was able to fish it back out with piece of stiff utility wire (wire close hanger would work as well) and needle nose pliers. I cut a piece of wire approximately 18 inches in length and formed a small hook one one end. I then fed the hook end thru the trim panel slit and snagged the door cable. Once the cable was hooked I slowly pulled the wire back out until I could see the door cable. I then took a pair of needle nose pliers and pulled the lever back thru the slit in the trim panel. Took a few tries but did not have to remove anything. you might give this a try before removing anything
Thanks guys, I ended up having to pull back the carpet and some trim but I found it. I'm going to try to put some kind of bushing on it to keep it from slipping behind the carpet again
Vette Jockey (04-28-2024)
Received 19,482 Likes
'20-'21-'22-'23-'24
Good luck and glad you were able to find the cable without a disassembly.
