I just bought one of those range devices to stop that annoying 4 to 8 and 8 to 4 cylinder switching ...works good except I'm pretty sure it knocked out my cruise controll ,,,anybody experience problems like this and have any suggestions on what can I check,,I checked abs and traction controll fusses cause there is no cruise fuses I see,,,I check the brake switch visually etc thanks tonycorvettehd@aol.com OK OK I FIXED IT I DISCONNECTED THE NEG AND POSITIVE BATTERY TERMINALS @ HOURS AND IT WORKS NOW >>THANKS FOR THE SUPPORT GUYS
Is the CC 'On"? The dash indicator is white-enabled and green on when engaged. dark when OFF. It will always stay enabled unless you touch the CC button on the wheel.
