Remove vinyl over lay
I have a vinyl over lay on the 3rd brake light that has deteriorated and I need to remove it before applying a new one. Any suggestions on how to remove it.
thanks
Fred
thanks
Fred
A few things that may help/work would be 50/50 alcohol, adhesive remover, or a heat gun. I would be very careful with the heat gun though. Try and start with some 50/50 alcohol and distilled water, that's what I have always used to remove adhesive or vinyl from cars.
Received 19,838 Likes
'20-'21-'22-'23-'24
All of the above are good suggestions. You could also try some WD-40 on the overlay.
St. Jude Donor '11-'12-'13, '15, '16-'17-'18-'19
Heat gun and plastic is not a good combination. I ought to know and I thought I was being careful.
It bubbled the paint right off the rear bumper
Not the current car.
Heat from a hair drier will do the trick. You don't need much heat. It should become pliable and peel right off. Then clean with denatured alcohol. Done this many times...
Vette E Boop (05-12-2024)
