Can't Seem To Find.....
........tire pressure numbers on my 2014 Z51 7MT 1 LT Conv. All I see is tire temp ("warm", etc.) Am I missing something or is tire pressure numbers not available on the '14? Love it, thought about a C8, it is very cool but between spending the difference and missing my stick (I have always owned one stick for the last half century from my first, VW bug, 2 Pintos, 1 Gremlin, 1 Miata GLC, 1 Honda CRX Si, 1 Toyota FX16 GTS, 1 Chevy Sprint turbo, 1 Subaru Loyale, 1 Ford Escort, 1 Hyundai Excel, 1 Miata, 1 Acura RSX, 1 Acura TSX, 1 Honda S2000, 1 Honda Accord Coupe and six Vettes/all manuals, whew)......
Moderator/Tech Contributor
Location: Jacksonville Florida BWO Dayton, Cincinnati, Bloomsbury NJ, Cincinnati
Received 3,862 Likes
2015 C7 of the Year Finalist
Mine is 30 PSI cold. '14 Z51 A6 19"/20"
Elmer
Elmer
Received 9,024 Likes
Bill
The following 3 users liked this post by Bill Dearborn:
Are you talking about the sticker in the door opening that lists the recommended pressures or the instrument panel display that shows you what they are? If you are talking about the display this is how you get to the correct spot. Using the control on the right side of the steering wheel push the left arrow until the IP highlight showing where the cursor is located moves as far left as it can move. When you have it in this position Info should be shown at the top with performance under that, etc. Next use the up arrow to highlight the Info section, then use the right arrow to move the cursor one step to the right followed by using either the up or down arrows to highlight the tire pressure display.
Bill
Bill
bearone2 (05-16-2024)
You guys got stuff my '14 didn't come with. Sigh..
Elmer
Elmer
Received 19,847 Likes
'20-'21-'22-'23-'24
Tire pressure info should be on a sticker in the driver’s door jamb. That is where it is on my 2014. 30 psi cold is the setting.
Vette Jockey (05-17-2024)
