Soler and aFe discount codes
Old May 29, 2024 | 10:16 AM
acs3931's Avatar
acs3931
Default Soler and aFe discount codes
Does anyone know if there is such a thing as a Solerengineering and aFe discount codes preparing to buy a throttle body and cai and thought I would see if they have savings for forum members
thx in advance
2019 Z06 A8
first go at mods
aFe intake
soler 87/91 TB
SpeedEngineering catless Xpipe
Old May 29, 2024 | 01:05 PM
I know Soler at times discounts their products. Give them a call and see if they are running any specials right now.
Old May 29, 2024 | 01:07 PM
acs3931's Avatar
acs3931
Will do, thanks for the tip
Old May 29, 2024 | 02:24 PM
Mike@SolerEngr's Avatar
Mike@SolerEngr
Supporting Vendor
thx in advance
2019 Z06 A8
first go at mods
aFe intake
soler 87/91 TB
Hi, not sure if you called today but you can use the code TIF5P at checkout for 5% off on your total order.
Old May 29, 2024 | 02:27 PM
acs3931's Avatar
acs3931
I did not call yet but I will use the code, thank you I appreciate the discount, looking forward to the mod,
Old May 29, 2024 | 02:52 PM
Mike@SolerEngr
Supporting Vendor
Glad to hear that. Let us know if there is anything else we can help you with.
Email: http://tiffany@solerengineering.com
Text/call: (850) 512-9262
Old May 31, 2024 | 10:30 AM
IA-SteveB's Avatar
IA-SteveB
You can't go wrong with Soler. The throttle controller and throttle body were my second and third modifications and both made the car way more enjoyable to drive. Not that it was bad, but I enjoy crisp throttle response quite a lot. I added an aFe Momentum CAI with a dry filter as well.
Old May 31, 2024 | 10:37 AM
acs3931's Avatar
acs3931
Thanks,
I ordered the TB already, should be here soon, I was teetering about the afe but I think the window on it looks cool , just as well do both at same time , was even thinking about painting the afe red with some sort of hi temp paint to match the car , ever heard of anyone doing that?
Old May 31, 2024 | 11:21 AM
IA-SteveB's Avatar
IA-SteveB
Thanks,
I don't know if I would do that, but that's just a matter of personal preference. I'd be worried about scratching it up during installation and the red may be a little overpowering.
Old May 31, 2024 | 11:38 AM
acs3931's Avatar
acs3931
That is true, I saw the Corsa red carbon fiber ones but did not think it was worth $1100 ,
What are your thoughts on tuning? I have been advised a tune not needed for my mods, I already have a range in place but wondering if selling it and getting hptuner (600 with credits) is better long term
Old May 31, 2024 | 11:45 AM
IA-SteveB's Avatar
IA-SteveB
You don't need a tune with the mods you are planning so far. Unless you are going to be doing a lot more stuff, you might be better off just having a shop do it on an as-needed basis, depending on your planned mods after the first round. You don't mention if you are a do-it-yourselfer, but if you are having a shop install bigger mods, just have them do it and take any guesswork out of it.
Old May 31, 2024 | 12:08 PM
acs3931's Avatar
acs3931
I guess since i already have the Range in place and these mods dont require tuning i will just let it run a while like this until i
get a feel for it, the only thing that I might do going forward is an AFM delete kit that actualy gets rid of the bad lifters
and physical pieces, that is not something i wouyld do my self so probably the shop that does the work would tune afterward
so an HPT might just be a waste,
Thanks for the insight
Old May 31, 2024 | 11:02 PM
Corvetteexhaustsystems's Avatar
Supporting Vendor
I'd be happy to set you up with the Corsa or aFe intake for your C7
Old Sep 29, 2024 | 11:31 AM
acs3931's Avatar
acs3931
mike,
I used the code above to purchase my tb, getting ready purchase controller is there a current code I could use,
the one above is expired
Old Sep 29, 2024 | 01:35 PM
v26278's Avatar
v26278
^^ probably better if you emailed them at the address provided
They seem to use a discount code for each month. The codes are usually posted here:
https://www.corvetteforum.com/forums...post1608137717
I’ve installed the throttle body in my GS as well as my current Z06. I highly recommend it
To Soler and aFe discount codes
