THE. ULTIMATE. ACCELERATION | Soler Performance
Old May 29, 2024 | 02:44 PM
Mike@SolerEngr's Avatar
Mike@SolerEngr
Supporting Vendor
Default THE. ULTIMATE. ACCELERATION | Soler Performance
Soler Performance
Website: General Motors — Soler Performance LLC (solerengineering.com)
Email: tiffany@solerengineering.com
Text/call: (850) 512-9262
SOLER | PERFORMANCE
Premium Modified, Ported, and Calibrated Throttle Body.
Check out the Soler Performance website to upgrade your throttle body.
Feel the difference.
Experience a lower weight-to-power ratio at part throttle, and a more nimble and sprinted drive. Along with crisper shifts, immediate response right off idling while keeping the idle function undisturbed, no requirement for tuning, more air/power at every single throttle position after idel, and easy installation.
Use code SALE5P at checkout for 5% off on your total order.
FEATURES: • Optimized Active Contours with sonic flow nozzles • Porting Taper and Upstream Bore with Velocity Stack • Greater Discharge Coefficient of Plate/Blade interface • 16 Ra Microinch, Diamond Polished Surface Finish • Shaftless high-pressure side of the blade for Larger WOT Flow Area (91 mm Effective Bore) • Self-Cleaning Throat/Flow Gap • Dome and Thread-locked Screws • Dimpled shaft trailing edge
BENEFITS: • Lower weight to power ratio at part throttle, for a more nimble/spirited driving experience • Linearization and smoothing of the curve for a more predictable response and crisper shifts • Immediate response right off idling while keeping idling function undisturbed (No Hesitation/Stumble) • Does not require tuning. Warranty safe. (LT5 only, LT1/LT2/LT4 may require tuning) • More air/power at every single throttle position after idle. Crucial for starting or expanding power gain
• Fully tested before shipping for sensor and motor operation, response time, and airflow.
Last edited by Mike@SolerEngr; Jun 3, 2024 at 10:52 AM. Reason: Updating Discount Code
Old Jun 3, 2024 | 12:06 PM
Mike@SolerEngr
Supporting Vendor
Soler Performance
Text/call: (850) 512-9262 mon-fri 9am-5pm
SOLER | PERFORMANCE
Old Jun 5, 2024 | 10:55 AM
Mike@SolerEngr
Supporting Vendor
Soler Performance
SOLER | PERFORMANCE
Old Jun 6, 2024 | 03:59 PM
Mike@SolerEngr
Supporting Vendor
Soler Performance
SOLER | PERFORMANCE
Old Jun 10, 2024 | 03:24 PM
Mike@SolerEngr
Supporting Vendor
Soler Performance
Website: Soler Performance | General Motors
Text/call: (251) 468-9786 Mon-Fri 8am-5pm
June Discount code: SALE5P
To THE. ULTIMATE. ACCELERATION | Soler Performance
