The. Ultimate. Acceleration
Old May 31, 2024 | 11:47 AM
Mike@SolerEngr's Avatar
Mike@SolerEngr
Supporting Vendor
Default The. Ultimate. Acceleration
Soler Performance
Corvette C7 Premium Portted Throttle Bodies And Throttle Controllers
Website:https://www.solerengineering.com/generalmotors
Discount Code:SALE5P
Email:http://tiffany@solerengineering.com
Text/call:(850)512-9262
THROTTLE BODY FEATURES:
• Optimized Active Contours with sonic flow nozzles
• Porting Taper and Upstream Bore with Velocity Stack
• Greater Discharge Coefficient of Plate/Blade interface
• 16 Ra Microinch, Diamond Polished Surface Finish
• Shaftless high-pressure side of the blade for Larger WOT Flow Area (91 mm Effective Bore)
• Self-Cleaning Throat/Flow Gap
• Dome and Thread-locked Screws
• Dimpled shaft trailing edge
BENEFITS:
• Lower weight to power ratio at part throttle, for a more nimble/spirited driving experience
• Linearization and smoothing of the curve for a more predictable response and crisper shifts
• Immediate response right off idling while keeping idling function undisturbed (No Hesitation/Stumble)
• Does not require tuning. Warranty safe.
• More air/power at every single throttle position after idle. Crucial for starting or expanding power gain modifications
Easy Installation
SE8223-040, 87 MM (91 MM EFF.) Corvette 7/8, Stingray/Z51/GS (2014-Present).
SE8223-080, 87 MM (91 MM EFF.) LT4 For engines, 6.2L Superchaged (LT4). Corvette 7, Z06, 2015-2019.
SE9871-100, 95+ MM / 100MM EFF. LT5/ZR1 Premium Modified Throttle Body (NEW) 95+ mm Ported or Modified to 100mm Eff. w/ Adapter Kit Optional Corvette C7 and C8 (LT1/LT2/LT4/LT5 Engines), 2014-Present.
SE1000-103 (103 MM TB) LT1 / LT2 / LT4 / LT5 / LS2 / LS3 / LSA + MORE Corvette 7, and 8 (2014+)
THROTTLE CONTROLLER FEATURES:
  • Dual control, directly on the display or remotely from your smart device.
  • Ten Modes, with a total of 64 possible settings (see chart).
  • Sturdy aluminum construction, buttons, and heavy-duty harness.
  • Self-adjusting OLED display intensity for optimum visibility.
  • Real-time throttle position gauge.
  • Fail-safe vehicle-specific design.
  • Does not require the display to operate, for those who prefer a fully concealed device.
SE0525-TC DLX BLUETOOTH® THROTTLE CONTROLLER: CORVETTE 7
PERFORMANCE
Last edited by Mike@SolerEngr; Jun 3, 2024 at 10:50 AM. Reason: Updating Discount Code
Old Jun 3, 2024 | 11:41 AM
Mike@SolerEngr
Supporting Vendor
Soler Performance
Text/call:(850)512-9262 mon-fri 9am-5pm
