Tire Balance
Old Jun 2, 2024 | 10:16 AM
C746490's Avatar
C746490
Default Tire Balance
Have any of you had your tires "Road Force Balanced" I was wondering if it made any difference and could you tell a difference - any comments and or advice are appreciated.
Old Jun 2, 2024 | 11:45 AM
kodpkd's Avatar
kodpkd
Looking at how they do it, seems like a great idea.
Old Jun 2, 2024 | 01:15 PM
Let It Ride's Avatar
Let It Ride
It's the only way I have done any of my Corvette's or any other car that I have owned. It takes into account every aspect of the tire and rim and matches them to each other. It measures low and high points in the wheel and tire construction, and measures lateral runout or radial runout.
Old Jun 2, 2024 | 01:33 PM
fuzzy03cls's Avatar
fuzzy03cls
Used it once to correct a tire problem with vibrations
Never had a problem with a regular balance.
Old Jun 2, 2024 | 03:11 PM
Gearhead Jim's Avatar
Gearhead Jim
St. Jude Donor '13
Yes, sometimes a regular balance will be just fine. But a road force balance might be a little smoother. If there's any unusual vibration after a regular balance, the next step is to take the wheels off and have them road force balanced. Discount Tires uses road force balancing on Corvettes without any additional charge I can notice.
Old Jun 2, 2024 | 09:21 PM
guido7834's Avatar
guido7834
I just had it done at Discount tire a couple months ago. It fixed the rhythmic vibration I was getting at highway speeds. And at no charge to boot even though I didn't buy them there.
Old Jun 3, 2024 | 01:13 AM
A road force balance is supposed to be the most accurate. If someone in your area has the equipment, that would be the way I would go.
Old Jun 3, 2024 | 11:01 AM
AnotherNorskie's Avatar
AnotherNorskie
I have done it but only because I suspect a wheel/tire problem and wanted to rule out balancing as an issue. I can't say it has ever been a night n day difference.
Old Jun 4, 2024 | 11:00 AM
MY04CE's Avatar
MY04CE
I highly recommend a road force balance for your Vette as well as any other vehicle you own. I always have this done on my Vettes. In fact, bought new Michelins for my GS from Tire Rack and had their mobile service install them, but their mobile service does not offer road force balancing. I took my GS to a tire shop and had them road force balance -- the extra $$ was worth it to me. Good luck.
Old Jun 5, 2024 | 09:09 PM
Avanti's Avatar
Avanti
Sure, go for it. But that said, we balanced our Bonneville racing tires with an old bubble-balancer for years without a single hiccup. They were good for 230mph. So, I guess if done right even that would still work on the street.
Old Jun 6, 2024 | 09:43 AM
CraigStu's Avatar
CraigStu
If you go to a Roadforce balancer be sure to specify that he use the 'Bullseye' function. I retired 12 years ago but that was the name of the function I used until then. The balancer is set up to allow a certain tiny amount of imbalance and call it good. They have 2 or 3 choices. My 12 yr memory may not be accurate here but the 'Automobile' function may allow 6grams imbalance and the 'Truck' function may allow 10grams and still show it is balanced on the printout. The operator chooses which function to use
To Tire Balance
