Not sure if this is the right forum for this question or not. I tried to search for a discussion regarding engine diagnostic scanners and found nothing.
What is everyone using? What does your scanner do for you? Do you use your phone for apps?
Most modern cars can run thousands of miles and many years without an engine issue requiring a code scanner. Most failures are nonpowertrain related thus requiring much more than an engine diagnostic scanner. This is what I use:
It requires the use of a PC to run the software but it provides most of the capability of the MDI2 tool used by GM Service techs. It provides scan and command capabilities so you can command systems which helps when diagnosing a problem. At least 45% of the codes that can exist on a car can't be seen by an OBD2-capable scanner. If something inside the passenger compartment stopped working I would first check the codes with this tool as there are codes for most systems on the car.
I use a Foxwell NT530. Originally purchased it when I had a Porsche (with Porsche-compatible software). When I sold the Porsche and took on the C7, I emailed Foxwell Customer Support and (for a very modest fee), they sent me the appropriate software for the C7 which I downloaded from my laptop. Its not the same stuff the dealer uses, but it scans the systems and gives me a pretty good idea of the issue (should the car have one).
