Z51 question
Old Jun 19, 2024 | 06:43 PM
C7nut's Avatar
C7nut
Default Z51 question
Probably no different but does a C7 Z51 shift at different speeds or differently then a base version?
Old Jun 19, 2024 | 07:08 PM
Gearhead Jim's Avatar
Gearhead Jim
St. Jude Donor '13
I believe the automatic shifts at the same RPM in either car, but the automatic Z51 has a higher (numerical) rear axle than the base car and so the shifts come at a lower mph. This probably improves the acceleration times, and definitely makes the car feel a bit "livelier".
Since I'm a shiftless guy, I don't know how it works out for the stick.
Old Jun 19, 2024 | 07:15 PM
gordoni's Avatar
gordoni
IIR, the gear ratios are numerically lower for the Z51 than the base. I don't recall the ratios at each gear, but having owned both a base manual and a Z51 manual, I can attest to the Z51 having a lower ratio in at least 1st and probably second.
Here's a link to an article that charts the gear ratios for Both the manual and the auto.
https://www.motortrend.com/news/1601-a-quick-look-at-the-corvettes-7-speed-triple-overdrive-transmission/
Old Jun 20, 2024 | 08:24 AM
C7nut's Avatar
C7nut
I drove a base model, and it felt different from my Z51. Thanks for clearing it up.
Old Jun 21, 2024 | 12:23 AM
Skid Row Joe's Avatar
Skid Row Joe
Yes. It's geared differently. Look up the GM specs online. It was something that I knew that I wouldn't use or want. I bought the Stingray w/o z51.
Old Jun 21, 2024 | 09:14 PM
Makes sense since the Z51 is more performance driving oriented.
To Z51 question
