C7 Trans triple flush
Old Jul 5, 2024 | 10:33 PM
Stan0324's Avatar
Stan0324
Default C7 Trans triple flush
Is the Triple flush required on a 2019 A8 or was it already resolved? Thanks
Old Jul 5, 2024 | 10:38 PM
M61A1MECH's Avatar
M61A1MECH
Active Streak: 90 Days
Read this TSB, it should answer all your questions.
File Type: pdf
Old Jul 5, 2024 | 10:50 PM
If your car was built after the date in the PDF file above, then you have the new fluid in the A8 and you should be good to go. Otherwise, having the triple flush done should be on the list of things to do.
Old Jul 5, 2024 | 10:58 PM
First Stingray's Avatar
First Stingray
I don't see a date in the PDF. When did Bowling Green fix the issue?
Old Jul 5, 2024 | 11:00 PM
First Stingray
Disregard, I see that it was fixed 2/1/19 on the C7. Thanks.
Old Jul 6, 2024 | 07:46 AM
Tinkertech's Avatar
Tinkertech
Its the build date of the transmission not the car.
There is a sticker on the transmission that states its build date.
If the date is after 2-1-19 you have the new fluid.
Old Jul 6, 2024 | 08:13 AM
Dcasole's Avatar
Dcasole
Hmmm , I don't think so ..... 99.9% sure its the date when they built the car and filled the trans with fluid ....
Dave
Old Jul 6, 2024 | 08:31 AM
George_L's Avatar
George_L
Tinkertech is correct. Here is the TSB showing the affected transmissions.
And here is a picture of the sticker from the transmission.
Old Jul 6, 2024 | 09:35 AM
Dcasole's Avatar
Dcasole
I stand corrected ! , i guess they fill them before install and then just top them off , or maybe they overfill them knowing exactly how much fluid it will take to account for trans cooler etc
Dave
To C7 Trans triple flush
