C7 Pause Before Acceleration
Old Jul 8, 2024 | 11:38 PM
DugT's Avatar
DugT
Default C7 Pause Before Acceleration
Yesterday I floored my C7, while in Sport Mode, to pass a car and the car had a significant hesitation before accelerating. It wasn't a problem other than it was scary for the moment I was in the wrong lane while it felt like the engine shut off. I suspect this is common and it is the traction control taking time to calculate. Please correct me if I'm wrong.
Today I accelerated quickly in Tr Mode and the response was immediate and wonderfully reassuring. Is there a good compromise between Sport and Tr or any other good solution to this? Do many people just use Tr mode unless just cruising or questionable traction? I'm a little reluctant to use Tr a lot because it makes it even more tempting to drive aggressively and because of the rougher ride. Also, I suspect the traction control is usually much safer.
Old Jul 9, 2024 | 02:13 AM
Vette Jockey's Avatar
Vette Jockey
Roadster Madness. 😠
St. Jude Donor '13, '20-'21
The only time I can remember the engine boggling down was when the revs got into the redline.
When, I am cruising on the Freeway and I want to pass someone, I put the shifter in manual mode, hit the paddles two to three times, and step on it.
The seat smacks me in the back and I am gone!
Old Jul 9, 2024 | 02:48 AM
Trooper944's Avatar
Trooper944
This has been an issue since ETC came about (and maybe before that?) and is not isolated to corvettes. I daily a '16 duramax with the same issue. Supposedly a 'throttle sensitivity booster' helps. I've also witnessed this same thing on a Cruze and an Acadia.
my post does nothing but tell you you're not alone, and it's lame.
Old Jul 9, 2024 | 06:25 AM
Raidercop's Avatar
Raidercop
Yes there is a wonderful solution...Soler Throttle Controller. It will wake your car up tremendously and give you complete control of your throttle response. Best mod for a C7 imo. I got the Bluetooth version. Easy install. Immediate results
Old Jul 9, 2024 | 08:58 AM
DugT's Avatar
DugT
It seems to me the easiest solution is to put it in Track mode before passing. Is ECT totally off in Track mode or just less cautious? I've never spun the tires in this car but I've spent little time in track mode and I've never tested its limits in track mode.
Edit: Today I will put it in track mode and punch it a few times to see how hard/easy it is to break the tires loose. Later I'll have my results published in Scientific American.
Old Jul 9, 2024 | 11:53 AM
Raidercop's Avatar
Raidercop
You remove the gas pedal unit and it plugs into that. 2 bolts I believe. Then control the settings from the app. Look it up on their site and YouTube videos. Maybe 20 mins to install. Very easy. Most other C7 owners have it. You can do a thread search on this site and see.
Old Jul 9, 2024 | 02:51 PM
DugT's Avatar
DugT
Thanks for recommending the Soler Controller. I read several other post about the Soler Throttle Controller and everyone loves it but there is something I don't understand. If the problem is the slow ECT, I don't see how the Soler solves that problem? Is the problem not the ECT? If not, what is Chevy's excuse?
Old Jul 10, 2024 | 01:04 AM
DugT's Avatar
DugT
This afternoon I accelerated fast in Sport and Track modes. In Sport, I didn't notice the lag that I noticed yesterday. Track mode was very responsive and it was more likely to be in a lower gear. This is a 2014 Z51. Maybe yesterday when I experienced a lot of lag, I was driving sedately until I found a place to pass and it took the car a moment to "Wake up" so to speak.
Old Jul 10, 2024 | 01:14 AM
corvettezman's Avatar
corvettezman
St. Jude Donor '11-'12-'13, '15, '16-'17-'18-'19
You may have been cruising in V4 mode and the car had to get out of that mode first to accelerate.
If you have the V4/ V8 mode active on your car, you need to get a range device to eliminate it.
I bought my car with the V4 mode written out of it with a tune by a previous owner and I love the fact that it does not go in V4 mode at all.
Old Jul 10, 2024 | 10:41 AM
Trooper944's Avatar
Trooper944
From my understanding, devices like the Soler change the "slope" of the signal sent to the ECM so, if 25% pedal WAS sending 25% throttle signal, now it will send 35% throttle signal at the same 25% pedal. (arbitrary made-up numbers for illustration). Makes the throttle signal 'less linear'.
at least that's been my understanding as I've seen it in the diesel world.
EDIT: please get rid of V4 mode if that's still kicking around in your engine
Old Jul 10, 2024 | 10:54 AM
DugT's Avatar
DugT
Thanks for the explanation about Soler. That is how I thought it worked. I would like to try it but I think it would not solve my specific problem. Now I suspect AFM/V4 is the culprit so I am considering getting a Range AFM disabler.
Edit: My Range... will arrive Friday.
Old Jul 10, 2024 | 11:43 AM
CraigStu's Avatar
CraigStu
Also note that traction and stability control are still active in Track mode. To turn them off you hold down the center of the mode **** until the two warning lights come on in the instrument display. The parameters of how much slip sliding they allow are different sport vs track but they are still working unless you manually turn them off.
Old Jul 10, 2024 | 12:20 PM
Jeff T.'s Avatar
Jeff T.
St. Jude Donor '13 thru '26
Just installed the non bluetooth Soler TC on our 2014. One bolt, simple install. Amazing results!! I have a Range as well.
Old Jul 10, 2024 | 12:34 PM
DugT's Avatar
DugT
Thank you! That is good to know. I suspected stability control was still on to some extent because I could not get a peep out of the tires.
Old Jul 10, 2024 | 01:30 PM
Leroyt10's Avatar
Leroyt10
You might try quickly stabbing the throttle quickly, releasing, then flooring it which should put it in performance shifting a light on the dash should verify it's engagement
Old Jul 10, 2024 | 01:57 PM
Gearhead Jim's Avatar
Gearhead Jim
St. Jude Donor '13
Wow!
Our 2017 Z51 A8 will spin the tires like mad from a standing start in Sport, TC on, if I floor it coming off the line. In some autocross events where the pavement isn't very grippy, I actually choose to start in 2 to reduce wheelspin. However, the PSS tires that came standard on the car (now on third set) make virtually no noise when spinning; just engine noise and a sort of "whirring" noise from the tires.
Old Jul 10, 2024 | 02:25 PM
DugT's Avatar
DugT
I didn't try spinning the tires from a dead stop. Spinning them isn't my goal so I will take your word for it that it is easy if you set it up for that. For now, I'm trying to learn more about the stability control on this car. I knew a lot more about this when I bought this car but that was a few years ago and I'm old....
To C7 Pause Before Acceleration
Old Jul 10, 2024 | 08:08 PM
IA-SteveB's Avatar
IA-SteveB
It still kills me that I spent $800+ to make the car drive how I wanted it to. That's a Soler TC, Soler TB, and a Range. Don't get me wrong, I love the results. . I normally cruise in Sport mode, SP9 on the Soler with traction control off, but I will occasionally drive in Tr with traction and stabilitrak off; kill mode so to speak.
Old Jul 10, 2024 | 10:16 PM
I’ll echo the comments about the throttle Improvement using the Soler Throttle Controller. I have it combined with one of their throttle bodies and the change is noticeable.
Old Jul 11, 2024 | 08:23 PM
DugT's Avatar
DugT
This morning I installed a new +Range. I tested it briefly and I think it solved the problem. There is a freeway onramp where the car used to significantly pause before accelerating and there was no pause today. I drive it daily and the lack of pause was conspicuous and excellent.
I don't have any other issues with the throttle response so I think I'm going with, "If it aint broke don't fix it." I think I don't want it to be even more fun to stomp on the accelerator.
