Jacking Question
Old Jul 15, 2024 | 09:23 AM
shakinrock's Avatar
shakinrock
Default Jacking Question
I'm getting ready to replace the front brake pads on my Z51. I prefer to jack up one side at a time using pucks. My question is, how far should I turn the wheel before jacking so that I can still remove the wheel and also have easy access to the back of the caliper?
Old Jul 15, 2024 | 09:24 AM
ZO6LIFE's Avatar
ZO6LIFE
I thought you can swap pads without removing the caliper?
Old Jul 15, 2024 | 09:37 AM
spoolin98's Avatar
spoolin98
You can, he mentioned nothing about removing the caliper.
Old Jul 15, 2024 | 09:38 AM
spoolin98's Avatar
spoolin98
You'll be fine not turning the wheel at all, there's plenty of room. Even a small amount of turn would probably be helpful, but not necessary.
Old Jul 15, 2024 | 09:46 AM
Maxpowers's Avatar
Maxpowers
No need to turn the wheels. Lotsa room in there with the wheel off.
Old Jul 15, 2024 | 12:01 PM
Squeaky Wheel's Avatar
Squeaky Wheel
Hope this isn’t a stupid question. But wondering, when jacking up the car from the side, do you have to use 2 jacks, one on the front jack puck position and one on the rear?
Old Jul 15, 2024 | 12:22 PM
Catfish4818's Avatar
Catfish4818
If you haven't already purchased new pads, I'd recommend PowerStop Z26s. I have them on our 2015 Z51 and brake pad dust on the wheels is almost zero.
And like has been mentioned, lots of room to access the back of the calipers.
Old Jul 15, 2024 | 01:05 PM
spoolin98's Avatar
spoolin98
No, you don't need two jacks.
Old Jul 15, 2024 | 01:07 PM
spoolin98's Avatar
spoolin98
I respectfully disagree. Worst pads I have ever owned. They stopped dust almost 100%, I will give you that. As for performance, they are trash. Company doesn't even provide cold performance data, at least they didn't when I researched it years ago. I had them on my car for about a week until I had to do an emergency stop with the brakes cold, never again. They were pulled off the next day.
Old Jul 15, 2024 | 02:09 PM
Catfish4818
Interesting. My initial (and still) reaction when they were installed was that they felt as good as the OEM pads.
I don't track my car; do you do so with yours? Is your car Z51 equipped?
If we both have Z51s, and neither of us track our cars, I'm at a loss to explain our widely different experiences.
Old Jul 15, 2024 | 03:53 PM
spoolin98's Avatar
spoolin98
They feel as good as OEM under normal street driving, but they don't perform on a performance level. At least not for me. I don't track my car, but I drive it spiritedly. Mine is a Z06.
Old Jul 15, 2024 | 04:07 PM
Maxpowers's Avatar
Maxpowers
My Z26s work great as a street pad. I bedded them. I swap out for track. Weather has been so wet here i havent gone this year.
Old Jul 15, 2024 | 04:11 PM
Maxpowers's Avatar
Maxpowers
Some may disagree but when I swap tires I jack up from the front so both tires lift off the ground. Then use jack stands front and back before getting to work.
Old Jul 15, 2024 | 04:46 PM
Squeaky Wheel
Just to clarify…..When you say from the front, are you saying you lift from the front side rail until both tires on that side are off the ground, or from the front end cross beam location until both front tires are off the ground?
Old Jul 15, 2024 | 05:10 PM
jamieo's Avatar
jamieo
These frames are so stiff you can get 3 tires off the ground while only using 1 jack.Not optimal,but it can be done!
Old Jul 15, 2024 | 06:35 PM
devnull's Avatar
devnull
Scientific Negotiator
St. Jude Donor '07-'08-'10, '14
I usually get a side done at a time. You can jack one spot and secure with Jack stands. No need to turn the front wheels.
Old Jul 15, 2024 | 08:53 PM
Not difficult to change out the pads at all.
Old Jul 16, 2024 | 12:21 PM
CB56's Avatar
CB56
Make a pair of these. The pins go in where the jacking pucks go. I cut rounds out of conveyor belt. Use a floor jack a little from the end of these and you can place blocks under these at the pin locations.
To Jacking Question
