Dod delete questions
Old Jul 21, 2024 | 12:50 AM
Miker6's Avatar
Miker6
Default Dod delete questions
Fresh rebuilt short block on my 2015 stingray, I did the dod delete,plugged towers, ls7 lifters, new cam. Turned off in tune as well. Using stock vlom cover with solenoids still there. My valve train is really noisy at idle. Is it the stock cover? I have 32-35psi oil pressure. Wasn’t sure if the stock cover wouldn’t work in this situation. Lifter preload is good. If I raise idle to 1000 it’s quiet
Old Jul 21, 2024 | 01:04 AM
96GS#007's Avatar
96GS#007
Hard to say without hearing it, but in general they are noisy.
Did you reinstall the foam insulation that Chevy installs over the valley cover? Ditto the other insulation that goes over the intake and under the beauty cover. Without those in place, you certainly hear the racket.
Old Jul 21, 2024 | 05:23 AM
DI motors are rather noisy, especially at idle. If all else is OK, bet it is normal.
Old Jul 21, 2024 | 07:08 AM
Miker6's Avatar
Miker6
Yes I understand that. But it was quieter before. Def loud clicking and diesel sound. I used btr stock cam for the afm delete.
I’ll get a vid when I get out there
Old Jul 21, 2024 | 08:58 AM
ZO6LIFE's Avatar
ZO6LIFE
It can sound like a sewing machine sometimes. Pretty normal.
Old Jul 24, 2024 | 11:17 AM
mittens's Avatar
mittens
So all my LTs have been cammed and they are not Nosier then before. New lifters, and cam, and all.
So did you get the correct push rod length? How much noise are we talking about
To Dod delete questions
