How often does AFM crash an engine?
Old Jul 26, 2024 | 12:10 PM
DugT's Avatar
DugT
Default How often does AFM crash an engine?
I've frequently read that AFM can cause a valve train to crash. How often does this actually happen? For example, does someone complain about it here about once per year or every five years? I doubt if anyone has any hard data about this, although that would be ideal.
Popular Reply
Jul 27, 2024, 10:07 AM
96GS#007's Avatar
96GS#007
Let's see......how many millions of the LT1 and the derivatives are out there? yeah.......a LOT. Are there unfortunate issues on occasion? Yes. Is it something that happens regularly? I'll say no or 1) the internet would be on fire 2) there'd be a recall of some sort and 3) in this sue-happy world I'd imagine a class action suit.
We might have an earthquake, a tornado, and a hail storm too.
Enjoy the car and quit worrying.
Old Jul 26, 2024 | 01:10 PM
Avanti's Avatar
Avanti
Try an "Advanced search" across the C7 Forums...
Old Jul 26, 2024 | 01:23 PM
JLSuperfly's Avatar
JLSuperfly
No idea but I got me a Range Device.
Old Jul 26, 2024 | 09:22 PM
9sec's Avatar
9sec
not "if" but "when".
Old Jul 26, 2024 | 09:25 PM
rjwvetttt's Avatar
rjwvetttt
2019 C5 of Year Finalist (appearance mods)
Great question if you ask me 🤔
Old Jul 27, 2024 | 12:10 AM
Skid Row Joe's Avatar
Skid Row Joe
Be interesting to see the stats on it, were it possible to know.
Old Jul 27, 2024 | 08:27 AM
larebob's Avatar
larebob
I'd guess warranty data is held closer than nuclear launch codes, but you can be sure the data exists. When I worked in chevy service in the early 80's I recall "Automotive News" had cost data printed for many makes - how they got it, who knows. I can only recall the Jag V12 was at the top by a long ways (my memory is it was in the thousands - wild in 1980's dollars). It might be easier to pry the data loose from the private warranty companies. They may not even care, as they just charge enough and go out of business fast enough that paying for some program to keep track doesn't pay!
Old Jul 27, 2024 | 10:07 AM
96GS#007's Avatar
96GS#007
Old Jul 27, 2024 | 11:44 AM
user051728's Avatar
user051728
If it was a statistically impactful number there would be enough complaints to have a recall. NHTSA uses pattern of defect (in addition to safety and regulatory) when a recall is issued. The number of failures for a pattern of defect is higher than the other two (where few cases are enough to drive a recall for safety and regulatory can have "zero cases" as its just factual), I don't think they have a number but its over a couple of percentage points of failure. So if there are millions of engines you'd need at least a few thousand failures.
Old Jul 27, 2024 | 12:01 PM
fatsport's Avatar
fatsport
No more likely to fail than the cheap chinese wheels on the market and they sell like hotcakes.
Old Jul 27, 2024 | 05:36 PM
Retiredsa's Avatar
Retiredsa
8th Gear
Don’t know what the percentage is but if it happens to you that percentage is 100%. I am one of those guys that buys an extended warranty on cars. For the cost of the Range device, it is cheap insurance and could help prevent a lot of hassle and frustration.
Old Jul 27, 2024 | 07:25 PM
aklim's Avatar
aklim
That makes no sense whatsoever. The percentage is the same whether it happens to you or not. So if it doesn't happen to me, the percentage is 0? 5% failure rate is 5 out of 100 whomever it happens to.
How does that work? If the lifter is weak and failure prone, whether it is pumped up or not, what is the difference?
Old Jul 27, 2024 | 10:23 PM
user051728's Avatar
user051728
I always get upset when it rains if the weather report is 0% chance, because technically anything over 0% chance means I can experience something, but 0% is 0%.
If the valve issue is over 0% it doesn't matter if you experience it or not, its greater than 0% so you could. In theory/math.
Old Jul 27, 2024 | 11:44 PM
Has there been engine failures due to something going wrong with the AFM system - yes and some stories have been posted on the forum. Just what percentage those failures represent - that is unknown for the average person.
Old Jul 28, 2024 | 08:53 AM
rjwvetttt's Avatar
rjwvetttt
Why not just start a sticky with a survey question that records the percentage?
Old Jul 28, 2024 | 11:51 AM
Punisher44's Avatar
Punisher44
AC Delco made a YouTube video about this happening it's called a missed timed event. In the event this happens you're cooked. Now how often, I don't know, like others have said the range device is cheap insurance. Even without the worry of a failure I don't like the fact of 4 cylinders being shut down. It's hard on the drive train including the tq convertor and tq tube couplings. The drive train has to compensate for the vibration. Here is the video of you would like to watch it explains the AFM
Old Jul 28, 2024 | 12:37 PM
DugT's Avatar
DugT
Thanks for all of the responses.
My reason for asking about AFM failure rates is I read about problems caused by AFM being activated after a long period of being inactivated by a Range or similar system. Apparently parts of the AFM system don't get lubricated as much when AFM is deactivated.
I recently installed a Range and I like not having the 4 cyl to 8 cyl lag. Since there doesn't seem to be enough data available to compare the risk of damage with and without a Range, I think I will drive without the Range for a couple days per quarter or something like that to keep it at least semi lubricated.
To How often does AFM crash an engine?
Old Jul 28, 2024 | 03:25 PM
aklim's Avatar
aklim
I have heard of that before but I don't believe the car is a human body that will atrophy if you don't use it. I don't think that is more than speculation.
Old Jul 28, 2024 | 04:10 PM
Exia's Avatar
Exia
A range device wont even prevent it from failing. Just because the lifters don't get used doesn't mean they won't break. They could just fall right out amd cause damage.
The range device shouldn't be seen as preventing failure but just preventing the poor transition between V4/V8 modes.
Your AFM tech can still break even if you don't use it. Its just another that can go wrong but nothing we can do about it. The chance does seem to be pretty low so I wouldn't worry about it.
Old Jul 29, 2024 | 09:02 AM
Tinkertech's Avatar
Tinkertech
"My reason for asking about AFM failure rates is I read about problems caused by AFM being activated after a long period of being inactivated by a Range or similar system. Apparently parts of the AFM system don't get lubricated as much when AFM is deactivated".
If this was true, then the 7 speed transmission model cars would be failing all the time since they never go into V4 mode except when you select Eco mode which I doubt not many people do.
