Paddle shift questions
Old Aug 2, 2024 | 11:45 AM
six-drums's Avatar
six-drums
Default Paddle shift questions
Please excuse my ignorance. My C5 auto didn't have the paddles or my C6 being a stick. l haven't tried using the paddles on my '19 before l ask. #1 do l need to release the gas pedal before the shift? #2 not to race or track but what is the RPM for the smoothest shift? #3 is it better to let it shift down on it's own or paddle down it myself and what's a safe RPM? If you have any helpful tips l would appreciate it. Thank you all.
Old Aug 2, 2024 | 11:49 AM
AZRenegade's Avatar
AZRenegade
C7 paddle shifting tips and tricks - CorvetteForum - Chevrolet Corvette Forum Discussion
Old Aug 2, 2024 | 12:21 PM
Squeaky Wheel's Avatar
Squeaky Wheel
Hi Six Drums, and welcome to the C7 community. I have a 2014 Z51 with the A6. I’m not a racer, just a cruiser with a few spirited sprints. I don’t worry about letting off the throttle between up shifts, and usually do so between 3-4K rpm. I will occasionally downshift with the paddles at various rpm’s if the mood strikes, but mostly just let it downshift on its own.
Old Aug 2, 2024 | 12:45 PM
six-drums's Avatar
six-drums
Wow, thank you guys! l will be trying this on the weekend. Thank you both.
Old Aug 2, 2024 | 11:45 PM
Have fun with the paddle shifters. They can be fun and make the car sound pretty good.
Old Aug 3, 2024 | 01:14 PM
bearone2's Avatar
bearone2
they a lot of fun but i still haven't figured out from a stop (only drops to 2nd gear), making a 90 degree turn, of how to upshift, when the wheel is turned, my fingers aren't on the paddles but i'll keep working on it!!
Old Aug 3, 2024 | 01:31 PM
LT4CMG's Avatar
LT4CMG
Try paddle extensions Bearone. Very useful for me. Had them matched to my caliper color
Old Aug 3, 2024 | 02:26 PM
bearone2's Avatar
bearone2
where'd you get the extensions??
thanks
Old Aug 3, 2024 | 03:33 PM
AZRenegade's Avatar
AZRenegade
Paddle extensions are the way to go. I've had a set in the past and they made shifting much easier. My only criticism of paddle extensions is that the lower extensions tend interfere with the volume and channel selection tabs on the steering wheel. I frequently use the steering wheel tabs to change stations or alter the radio volume. In doing so, occasionally, I would inadvertently hit the lower shift tab. Sometimes the system would ignore the accidental shift request and sometimes it wouldn't, but it always caused me to focus on the tabs and not the road. It's not a deal breaker but it is something to consider. As far as shifting in turns, if you slow down your shifting process, eventually muscle memory will take over and you will be shifting quickly without even realizing it. Practice, practice, practice.
Old Aug 4, 2024 | 07:50 PM
kodpkd's Avatar
kodpkd
I have been through a few different shifting methods with my 2014 A6. At first I just used it in auto mode, then it was more fun to paddle shift. I started paddle shifting aggressively up and down through the gears. Then I started reading about the torque tube issues. I figure hitting the gears up, then bang the down shift probably isn't doing the drivetrain any good. Now I am using the manual mode 99% of the time. Two issues this helps with. 1. You will shift about 1/2 as many times in manual than in auto. 2. I can control when to shift. If I am just driving in town I don't go much over 3500 rpm's and rarely go above 4th. I down shift a bit above 1000 rpm's and can tell it isn't putting stain on the trans. I have just started leaving it in second, if I know I am not going to need a fast start. Of course there are the times I drive it like a Corvette but no need to beat the car all the time..
I also got the fake carbon fiber shifter extensions.
To Paddle shift questions
