Steering Wheel Reset
Old Sep 24, 2024 | 08:05 PM
Bobby B's Avatar
Bobby B
Default Steering Wheel Reset
My steering wheel no longer retracts when the engine is shut off. How do I reset it. Thanks in advance.
Old Sep 25, 2024 | 08:59 AM
corvettezman's Avatar
corvettezman
St. Jude Donor '11-'12-'13, '15, '16-'17-'18-'19
does it retract when you do it through the switch on the column?
If so, then all you need to do is to reprogram your exit setting with the wheel retracted or lifted.
You also need to make sure your easy exit setting is not turned off in the comfort settings.
Old Sep 25, 2024 | 04:26 PM
Old Sep 25, 2024 | 08:22 PM
ball-z's Avatar
ball-z
check to make sure you are using the right key fob fob 1 program may be different from fob 2 program
Old Sep 25, 2024 | 10:53 PM
Stika's Avatar
Stika
Old Sep 26, 2024 | 05:20 AM
76-Vetteman's Avatar
76-Vetteman
Don't know what year OP has, but this video helped me to get the automatic functions of the seats and steering wheel worked out.
Hope this helps..
To Steering Wheel Reset
