Flickering climate control
Old Oct 7, 2024 | 03:49 PM
Undatakr's Avatar
Undatakr
Default Flickering climate control
I’m hoping I’m not staring down the rabbit hole of electrical issues but my “new to me” 2014 Stingray has a minor (I hope) issue. The lights that illuminate the climate control panel flicker, there is no other problem with the climate control, everything works as it should. There is no other flickering of any of the dashboard lights, just those of the climate control. I’m thinking a loose ground wire but does that portion of the dash have its own ground? Thanks in advance for your advice and suggestions!
Old Oct 7, 2024 | 04:10 PM
jamieo's Avatar
jamieo
Looking at a spare pane I have it appears that the climate control plug is a seperate plug.It doesn't go to the radio display.just the climate control.Your thought sounds logical but I don't have the pinout handy to see the wiring schematic.Sorry I am not much help!
Old Oct 7, 2024 | 10:59 PM
Worth a shot to investigate the plug going into the climate control. Hopefully it will turn out to be an easy fix.
To Flickering climate control
