tire milage
Old Oct 25, 2024 | 12:18 AM
airspeed's Avatar
airspeed
Default tire milage
how many miles can you expect to get on DD MICHLEM A/S TIRES? AFTER 2/1/2 YEARS I HAVE AROUND 23 000 MILES FRONT TIRES THREADS ARE GETTIN LOW
Old Oct 25, 2024 | 12:47 AM
Lots of factors when it comes to tire mileage, but if PSI levels are right and good alignment, I would say 25-30K miles on a set should be attainable.
Old Oct 25, 2024 | 03:07 AM
M61A1MECH's Avatar
M61A1MECH
Active Streak: 90 Days
I just had all 4 of mine changed and had 26K on them, the fronts were due and one rear picked up a nail. Just for reference 95% of the miles were in Florida where the roads are generally in good shape.
Old Oct 25, 2024 | 01:54 PM
MY04CE's Avatar
MY04CE
I took off my Michelin A/S tires at 40K and they still have 6-8 mm tread left. Put Forgeline wheels and new Michelin A/S tires on at 41K miles. Key to tire wear is proper alignment, front and back (don't use the standard GM front alignment specs as they will wear the inside quickly (GM uses a track align spec on GS). Rotate the tires side-to-side approx every 7-10K miles and ensure tire pressure is maintained at 30 to 32 psi cold all the time. This should give you the best mileage possible. Good luck.
Old Oct 25, 2024 | 02:22 PM
orca1946's Avatar
orca1946
Mine only have 13K so I'm still good.
Old Oct 25, 2024 | 05:34 PM
Skid Row Joe's Avatar
Skid Row Joe
Got less than this ^^^ on my A/S Michelin Run Flats.
I'm still good.
Old Oct 25, 2024 | 07:54 PM
Gearhead Jim's Avatar
Gearhead Jim
St. Jude Donor '13
The A/S Michelins last almost twice a long as the summer PSS, and the cost is less. Those who run the A/S all year cut their tire cost-per-mile nearly in half, if you care.
Old Oct 25, 2024 | 08:02 PM
ZO6LIFE's Avatar
ZO6LIFE
I'll let ya know in 5 to 10 years
Old Oct 25, 2024 | 09:48 PM
C5FORFUN2's Avatar
C5FORFUN2
What alignment specs do you use? I'm ready to get mine checked.
Thank you
Old Oct 25, 2024 | 10:07 PM
jamieo's Avatar
jamieo
camber-alignment-settings.pdf
Old Oct 25, 2024 | 11:26 PM
airspeed's Avatar
airspeed
thx for all the replys i guess i am on the right tack i like the a/s run flats i still have some time left
Old Nov 1, 2024 | 12:57 PM
MY04CE's Avatar
MY04CE
Thank you
I use the attached DSC alignment specs yearly and it solved the wear problem.
File Type: pdf
Old Nov 1, 2024 | 03:49 PM
Mad*Max's Avatar
Mad*Max
I can confirm that the summers wear very fast, the fronts on mine were worn at 12k miles (even wear)?
Old Nov 1, 2024 | 04:37 PM
C5FORFUN2's Avatar
C5FORFUN2
Thank you
To tire milage
