C7 Ported Throttle Bodies - Soler Performance
Old Nov 11, 2024 | 03:18 PM
Mike@SolerEngr's Avatar
Mike@SolerEngr
Supporting Vendor
Default C7 Ported Throttle Bodies - Soler Performance
Explore our offerings and elevate your C7 performance today.
Visit our website or contact Tiffany at (251)468-9786 or tiffany@solerengineering.com
Available Monday-Friday, 9-5 CDT.
Use discount code TIFF5OFF for extra savings.
Link to 91mm Throttle Body: SE8223-91
FEATURES:
• Optimized Active Contours with sonic flow nozzles
• Porting Taper and Upstream Bore with Velocity Stack
• Greater Discharge Coefficient of Plate/Blade interface
• 16 Ra Microinch, Diamond Polished Surface Finish
• Shaftless high-pressure side of the blade for Larger WOT Flow Area (91 mm Effective Bore)
• Self-Cleaning Throat/Flow Gap
• Dome and Thread-locked Screws
• Dimpled shaft trailing edge
BENEFITS:
• Lower weight-to-power ratio at part throttle, for a more nimble/spirited driving experience
• Linearization and smoothing of the curve for a more predictable response and crisper shifts
• Immediate response right off idling while keeping the idling function undisturbed (No Hesitation/Stumble)
• Does not require tuning. Warranty safe.
• More air/power at every single throttle position after idle. Crucial for starting or expanding power gain modifications
Available Options:
NEW: Brand new, reworked part (0 miles / BNIB).
CORE EXCHANGE: Refurbished, shipped immediately with a $120 deposit refunded upon receipt of your unmodified core.
REFURBISHED: Refurbished part with no deposit or core return needed.
REWORK YOUR OWN: Send your unmodified unit, and we’ll rework it within 1-2 business days.
Please contact us if your unit has been modified or ported.
Link to 95mm Throttle Body: SE9871-100
FEATURES:
• Shaftless high-pressure side of the blade for Larger WOT Flow Area (100 mm Effective Bore)
• Includes a high-efficiency, Manifold Specific Adapter Kit for LT1/LT2/LT4 engines
BENEFITS:
• Does not require tuning. Warranty safe. (LT5 only, LT1/LT2/LT4 may require tuning)
Link to 103mm Throttle Body: SE1000-103
FEATURES (103MM):
• Body and Sensors calibrated as a match set, zero intrinsic calibration issues
• Porting Taper and Upstream Bore with Velocity Stack (Lip & Bore Reduction)
• 16 Ra Microinch, Diamond Polished Surface Finish (Lower Skin Friction)
• Dimpled Pattern on shaft trailing edge.
• Dual-purpose hole pattern, the innermost part provides a direct fit to the MSD and all LT1/2/4 manifolds/superchargers, or aftermarket superchargers. The outermost provides a direct fit to the LT5 (ZR1) supercharger.
BENEFITS:
• Essential component in high-performance engine modification, with exceptional high flow capacity
• Lower weight to power ratio at part throttle, for a more nimble/spirited driving experience
• Immediate response right off idling while keeping idling function undisturbed (No Hesitation/Stumble)
• Does not require tuning to run, but tuning is highly recommended for optimal performance
• No drivability, idle, tuning, or similar issues relating to similar-sized throttle bodies.
PERFORMANCE:
• Wide-open throttle flow: 1600 +/- 50 SCFM @ 20” H2O at WOT.
• Designed for drivability; no tune required (highly recommended for optimal performance).
• Max Area ETC scalar : 5396mm²
• Max Geometric/Flow Area: 7466mm² (do not use as area scalar in tune)
• Fully tested before shipping for sensor and motor operation, response time, and airflow.
Feel free to reach out with any questions or to place an order.
Old Nov 14, 2024 | 09:09 AM
Mike@SolerEngr
Supporting Vendor
Old Nov 15, 2024 | 02:07 PM
Mike@SolerEngr
Supporting Vendor
Old Nov 21, 2024 | 09:24 AM
Mike@SolerEngr
Supporting Vendor
Old Jan 29, 2025 | 03:12 PM
Mike@SolerEngr
Supporting Vendor
To C7 Ported Throttle Bodies - Soler Performance
