The dreaded "shudder", or something else?
Old Nov 26, 2024 | 03:08 PM
Redhook98's Avatar
Redhook98
Default The dreaded "shudder", or something else?
Just bought a pristine 2016 Z06 with 22k miles. All service records, etc appear to be available. I was not sure what to look for with the shudder issues with the A8, so I installed a Range device to eliminate this potential issue. Lately, I have been taking it on longer and longer drives and I started notice a strange harmonic when at constant RPM/Speed that comes and goes regularly. No shudder or issues seen when shifting, only this strange harmonic/vibration when at highway speeds. Is this part of the shudder issue where I should get the triple-flush done? Or likely something else? Is the shudder only seen during shifts?
Thanks!
Old Nov 26, 2024 | 04:16 PM
Dcasole's Avatar
Dcasole
Anything that rotates can setup a harmonic vibration, I had never had the shudder, I had a new set of tires put on and had then ROAD FORCED balanced. I jumped up on the highway to make sure I had no vibrations and guess what ... I had the same rhythmic vibration that you are describing
I drove right back to Discount, and they had to redo the balancing 2 more times with the last one being done as a BULLSEYE balance .... it's been 3 years since that day, and I do not have any vibration
This is the exact reason what so many people bash the A8, they complain about a vibration and the dealers just automatically default to do the trans flush with no diagnosis being done at all ... then when the flush does not fix the problem, the customer bashes the transmission
This was the reason why originally GM required a dealer to do a PICO test as that will pinpoint what is causing the vibration, not sure why they relaxed that requirement
Good luck and keep us posted
Dave
Old Nov 27, 2024 | 11:00 AM
Markmbaha1's Avatar
Markmbaha1
Dave
I recently purchased 2018 Stingray Z51, A8. I also recently noticed an increase vibration starting maybe 40-45 mph. It greatly depends on the road surface. I thought of tire balance. I was not aware of the shudder issue, trans fluid change, and the fuel management problem dropping to 4 cylinders.
Old Nov 27, 2024 | 12:11 PM
corvettezman's Avatar
corvettezman
St. Jude Donor '11-'12-'13, '15, '16-'17-'18-'19
I just had the triple flush done. When you have the shudder, you can't miss it. It's very pronounced.
I know of rhythmic vibrations. I have had them before. They're not shudders.
My shudders happened only on shifting and never while cruising. Mine would happen when you downshift from 7 or 8 to a 4,5, or 6 to accelerate.
You need a road force balance.
Old Nov 27, 2024 | 12:22 PM
Markmbaha1's Avatar
Markmbaha1
I'm unfamiliar with Shudder but can imagine the feeling. i also have a rough idke and can also feel it at the end of a stop slmost like an out of round rotor. Also mine never auto downshifts into 2nd gear. Every time slowing to a stop, very slow stop, normal stop, it hangs in 3rd then 1st, then rough idle. So no way to stop without roug pulse feel. 23k miles and dealer said Bembro slotted disc are fine. 2018, Stingray, Z51.
Old Nov 27, 2024 | 12:27 PM
Skid Row Joe's Avatar
Skid Row Joe
45 years ago I bought a new 1980 Lincoln Town Car that had the new "4th gear" Overdrive. After a few tens of thousands of miles, it developed a shudder when shifting into overdrive. But not all the time. The car would buck like a bronco, violently. Nothing came of it though. I would just coast by taking my foot off the gas. And it would seem to heal its violent eruptions of bucking, and I carry on my highway drive.
Never addressed it with a Lincoln dealer, and never had a breakdown. Just kept driving it to 286K in 16 years .
Old Nov 27, 2024 | 12:51 PM
Steel City's Avatar
Steel City
Thanks!
Check these posts out -
https://www.corvetteforum.com/forums...er-speeds.html
https://www.corvetteforum.com/forums...vibration.html
Old Nov 27, 2024 | 01:58 PM
Redhook98's Avatar
Redhook98
I am unfamiliar with a road force balance. Can any tire place do this? Tire have about 1200 miles on them. Michelin Pilot Super Sports.
Old Nov 27, 2024 | 02:55 PM
Markmbaha1's Avatar
Markmbaha1
I just called my Chevrolet Cadillac dealer. The service advisor didn't know whst it was. She went away and came back a few minutes later and said it's $200.00 and regurlar balance is $125.00. But, how would i know if they really did it, is my question.
Old Nov 27, 2024 | 05:20 PM
TxLefty's Avatar
TxLefty
Take a look at their balancing machine. If it doesn't have a roller that presses on the tire while it's being spun, then it isn't a road force balancer. As far as I can tell the Hunter Road Force Elite is the top of the line. They should be able to give you a road force score for each wheel/tire. The lower the better.
Old Nov 27, 2024 | 05:46 PM
Dcasole's Avatar
Dcasole
You need a Clear Adapts and Garage Relearn Procedure , it will fix all of that for you !
As far as the rough idle , no corvette idles like a Cadillac... they all ide rough, proce u pay for performance
Dave
Old Nov 27, 2024 | 05:51 PM
Dcasole's Avatar
Dcasole
I would run ... fast from that dealership , do you have a Discount Tire store or a Tire Discounters near by .... ?
Old Nov 27, 2024 | 07:39 PM
Markmbaha1's Avatar
Markmbaha1
Dave
Ok so ckear adapts us simply disc battery for a few. I cant find Garage Relearn Procedure (only garage door opener relearn. Can you point me ?
I've owned 5 C5's and 1 C4. not one had a rough idle. I started my c5 today and it idols very smooth. This c7 is rough. And sometimes the rough idle is much worse than others. Idk . Any pointer on garage relearn Procedure is appreciated.
Old Nov 27, 2024 | 08:07 PM
Dcasole's Avatar
Dcasole
Ok so clear adapts us simply disc battery for a few. I cant find Garage Relearn Procedure (only garage door opener relearn. Can you point me ?
U can't go a clear adapts or do a garage relearn without professional scan tool like GM's GDS2 , or a high dollar Autel .HP Tuners while not a true scan tool can do it also
Removing battery cables will not clear ADAPTS
See my post in this thread on what a garage relarn does
https://www.corvetteforum.com/forums...ogramming.html
As far as the rough Idle .....
The C7 makes 460 hp stock and will run a low 12 second , high 11 second quarter mile time which is crazy for a 3,600 pound car with full options ...your C4 does not even come close to making that much Horse Power and torque nor did the LS1 in your C5. Compaired to a C6 LS3 or a C7 LT1 they both were slugs
All this power comes at a cost .... a bit of a rough idle , it's the cam shaft and it's lift and duration that make the power. It's not your fathers Buick ......and never will be
Old Nov 27, 2024 | 08:28 PM
Markmbaha1's Avatar
Markmbaha1
I wonder why some idles are so much more rough than others. It did not idle like then when I test drove it.
Old Nov 27, 2024 | 08:38 PM
Dcasole's Avatar
Dcasole
Well , whoever does your Garage RELEARN, they can can alo scan the rest of the modules to see if there are any issues ......
Dave
Old Nov 27, 2024 | 08:41 PM
Markmbaha1's Avatar
Markmbaha1
Dave
Thanks. After tax return if I don't sell it by then. I should not have gotten the Z51.
To The dreaded "shudder", or something else?
Old Nov 27, 2024 | 08:59 PM
Dcasole's Avatar
Dcasole
Not sure why , they are great cars .... my 15 has 62,000 miles on it and I drive it almost as a daily. It has been procharged for the last 3 years or more and is very reliable . I am lucky in the fact that I am able to work on and do almost any repair that is needed but in 62,000 miles it's only needed a few repairs
Every Hi Performace car has its issues , get the garage relearn done , and scan it to make sure nothing else is wrong with it and it can be the most fun car you will ever own
Dave
Old Nov 28, 2024 | 08:47 AM
guido7834's Avatar
guido7834
Thanks!
Get your tires a good road force balance. I had this issue at highway speeds of about 60-65 mph. This is where I'd start. Discount tire did it for free.
Old Nov 28, 2024 | 10:34 AM
Markmbaha1's Avatar
Markmbaha1
Thank you. My dealer told me $200.00. Why did they do yours free? Did you buy from them?
