Quick Jack
Old Nov 28, 2024 | 08:01 PM
acs3931's Avatar
acs3931
Default Quick Jack
All,
can any of you with Quick Jack experience shed light on a couple issues before i purchase
z06
1; which model are you using ? it looks to me like the 5000TL is the choice, 7000 lbs and xtended rails not needed for 2019 Z06
2; i am looking to get a little more height, has anyone used a proces of supporting the car on wheel stands once lifted then lowering the jack and puting
something like the SUV or other blocks in place to extend the height?
Old Nov 29, 2024 | 12:42 AM
NortonCO's Avatar
NortonCO
I went with 5000TLX, which works well for my '19 Z when turned perpendicular to the car, as shown here...
It also works well in the more "normal" parallel setup on everything else in my garage.
The shorter (5000TL) model works in the more "normal" parallel setup for C7s, but is too short for many other vehicles.
I can't speak to your second question.
Old Nov 29, 2024 | 07:37 AM
C5Dan's Avatar
C5Dan
Went with the Quick Jack 5000. They work great for my 19GS. Never extended the height as you asked, while very solid and stable I would not push the envelope.
Got mine at Home Depot at a great price with military discount.
Old Nov 29, 2024 | 08:47 AM
kodpkd's Avatar
kodpkd
From Amazon
Old Nov 29, 2024 | 01:43 PM
acs3931's Avatar
acs3931
Thanks for input, and Dan thank you for your service ,
My main concern about the extended height was how well the quickjack lowers with no weight on it, if it struggles to go down or goes very slowly my plan may need re thought
Old Nov 29, 2024 | 01:46 PM
Gixxerman's Avatar
Gixxerman
Moderator
St. Jude Donor '18 thru '25
They go down fine, slowly, they do not struggle to go down without weight unless they were not setup properly as per instructions
Old Nov 29, 2024 | 01:50 PM
acs3931's Avatar
acs3931
Thank you , makes choice easier , now just looking for done Black Friday sales, seems like 1500 bucks is about it I have seen
Old Nov 29, 2024 | 02:10 PM
Beast's Avatar
Beast
I have the quick jack 5000TLX for my C5, TLX is actually about 1-2inches to long. I have to use a short rubber block with puck in the rear and just a large rubber block on the front with no puck. Works well that way, make sure the large rubber block in the front does not hit the fiberglass under the car and it’s fine. Never got extra height out of it, and never tried it on a C7.
To Quick Jack
