What scan tool for npp relearn
I bought an older refurbished Dell and a Lenovo off of Amazon that I used specifically for my diagnostic tools for my car, I have HP Tuners for my ECM/TCM tuning needs and for diagnostics
I have $200 tied up in the laptop (I did not need two, but you will see the reason below why I bought a second lol) and $125 in the VX DIAG Nano so for $325.00 I have the most powerful diagnostic software available for GM cars (others makes are available)
Tech II WIN (older GM software) and GDS2 (Newer GM 2011 to 2019) does everything a dealer can do, reading and resetting codes, module relearn, programing, diagnostic procedures like commanding specific modules to perform, (IE you can command the trans to hold a gear, command the Antilock system to stay open when bleeding brakes ETC, ETC). it does a lot more. I specify like reading all modules and getting the report on if there were any issues. it also monitors every PID in real time and has a SCOPE function
You can also use the VX DIAG module as an MDI communications device to download updates from right from GM's Website. it's a powerful tool and it's the best diagnostic tool that does not cost a fortune
Loading the software is a pain in the butt as there really is not any support but if you are a little computer savvy, it's not bad, if you are not computer savvy, they sell version with it preloaded on a hard drive hard drive that you can install or use as a secondary USING a USB Hard drive dingle that you can buy anywhere
There is a wireless version of the VX Nano, but I caution people not to buy it as it just adds l complexity to the install, stick with the USB wired connection
VX DIAG NANO
USB Version VXDiag VCX NANO for GM/OPEL 2024.5.8 G-D-S2 Tech-2-WIN Diagnostic Tool
Amazon.com: VXDIAG VCX Nano GDS2 and Tech2Win Diagnostic Tool Compatible for GM/OPEL with Global Diagnostic Programming System GDS & GDS2 Blue : Automotive
Hard Drive
Or buy the hard drive 2TB Hard Drive with Full Brands Software for VXDIAG MULTI TOOL
This hard drive has all the different manufacturers diagnostic software ...... I can't speak to how they work except for the Mercedes Benz Software as I have used that
Laptops
The laptops that it works best on are
LENOVO T420 T440 X201, DELL E5420 E6420, Panasonic CF53 54 31.
I made sure the laptops I bought had at least a ICORE 5 processor and 16 gig of ram (I had to add a stick to one, but it was super cheap). They are plenty fast, and the only downside is that they are not as small and light as newer models. I am going to try and load the Software on a windows tablet as that would be the ultimate experience. I will keep you posted
Been using this on my car and all my friends' cars for years now (lol they all know I got this, and HP tuners and they all call me when they need it, hence the 2nd laptop lol)
Dave
Dave
There are tons of scan tools for sale and it depends are what you plan on doing with them. The Xtool D8 is a step up from my D7S but for me really isn't worth the extra cost. You can spend $1000 and up on a tool but will you use all it's capabilities?
There are tons of scan tools for sale, and it depends are what you plan on doing with them. The Xtool D8 is a step up from my D7S but for me really isn't worth the extra cost. You can spend $1000 and up on a tool but will you use all it's capabilities?
The Androids are nice, but the OP specifically asked to access his NPP, not sure why .... I bought an Android scanner for my Mercedes as I needed to reset the Anti- Pinch on the sunroof after replacing the tracks, the WEB site stated that it could do it, and even the manual told you the menu levels you needed to use to access it , I install my new tracks plugged in the scan tool and I could reset almost every module .... (Seats, Windows, Truck Release, Parking Brake) EXCEPT the sunroof ......the menu they specifically sated was there not there lol, I ended up taking it to my local shop that I am friendly with, and they used their MBEZE software to reset it for me no charge, so i bought them all lunch .....
Dave
"Innova CarScan Code Scanner: Bidirectional & Active Test, Special Resets, Free Fix and Part Recommendations
- Bi-directional control/ Active Tests: Allow you to send commands to your vehicle in order to test functionality just like a dealership mechanic would.
- Special Reset Function: Gives you the ability to use dealership level relearn procedures to complete repairs or maintenance
- Enhanced Data Stream: view live data for advanced systems such as ABS, SRS, transmission and engine
- Full Vehicle Module Scan: Modern vehicles can have up to 150 separate ecu modules that have their own trouble codes. This powerful function can read and clear them all.
- TPMS: Read
- ABS/SRS: Read and Clear on Domestic / Asian / European vehicles
- Oil Light reset
- Battery Initialization/Reset
- View Live Data
- SMOG Check LED Indicators
- Code Severity Levels
- DPF Regen"
- TPMS: Read
- Oil Light reset
- View Live Data
- DPF Regen"
It looks good by the specs ....... but so did my Mecedes Scanner ...... The one thing that I bought it for, and the spec said it did, it did not do,
Looking at his scanner I do not believe you will be able to RELEARN a NPP or an AFM valve
What specifically are you going to use it for
Dave
I have
Dave
I have
Limited-time deal: XTOOL D7S OBD2 Scanner Diagnostic Tool, Upgrade of D7, 36+ Resets, Bidirectional Scan Tool with ECU Coding, 4000+ Active Test, All System Diagnose, Crankshaft Relearn, CAN FD/DoIP, 3 Years Update https://a.co/d/iztd3DA
Dave
