slight rattle upon acceleration
Old Dec 6, 2024 | 09:55 AM
streetglider10's Avatar
streetglider10
Default slight rattle upon acceleration
My 2014 has developed a slight rattle that sounds like it is coming from underneath the passenger side of the car. It seems to occur only when accelerating normally in traffic. It only lasts a few seconds but is becoming more frequent. I have listened to several torque tube rattle videos, and it does not sound the same to me. Unfortunately, I am in Florida for the winter and don't have access to my Quickjack or tools to get under it and look around. My questions are: Is it possible the torque tube is going bad? If I could find a way to lift it, is there anywhere I should begin looking? The car seems to run fine and the only other issue is a bad headlight! It has 47,000 miles on it. Any suggestions for me? Thanks in advance, I have received a lot of great information on this site.
Old Dec 6, 2024 | 10:38 AM
TxLefty's Avatar
TxLefty
I'll make something up and say that it sounds more like something loose in the exhaust or perhaps an exhaust/heat shield.
Old Dec 6, 2024 | 11:09 AM
car2fast4you's Avatar
car2fast4you
If it's a manual transmission, the shifter could be rattling.
Another thing to check is the tunnel plate (under the car) that covers the torque tube & the exhaust x-pipe. I believe that there are 24 bolts that hold it on. Check to make sure that they're all tight, and that none of them have worked their way loose. I had that issue on my C6.
There are also things inside the door that can rattle. Several C7 owners have reported that problem.
Old Dec 6, 2024 | 01:17 PM
c5arlen's Avatar
c5arlen
My bet is a broken weld or joint inside the muffler / cat converter.... Time for new sexy exhaust setup.
Old Dec 6, 2024 | 07:13 PM
streetglider10
Thanks everyone. I'm trying to determine a way to get under it and take a look.
Old Dec 7, 2024 | 12:19 AM
I had a slight rattle on my car and it turned out to be a belt tensioner. Maybe worth checking it out.
Old Dec 7, 2024 | 08:33 AM
streetglider10
Sounds like a good idea. I've been meaning to check the belt tensioner after reading about some issues with it on here. I've looked at a few videos but if I need to take the shroud off, that may be a problem for me where I'm at now.
Old Dec 9, 2024 | 12:24 PM
DoubleG's Avatar
DoubleG
Sure it's not spark knock?
Old Dec 9, 2024 | 07:47 PM
streetglider10
Default rattle
I researched spark knock after receiving the post but it does not sound like my issue. Thanks.
To slight rattle upon acceleration
