Dead battery
Old Dec 12, 2024 | 09:47 AM
zcarmaniac's Avatar
zcarmaniac
Default Dead battery
I have been in hospital for 42 days,,,my 2018 Z06 will not even let me open the car doors or the deck lid ,,,,Any suggestions?
Old Dec 12, 2024 | 09:50 AM
etaylor14's Avatar
etaylor14
Did you try the key?
Old Dec 12, 2024 | 10:05 AM
^ If not, give it a try. Doing that should allow access to the manual door release wire.
Old Dec 12, 2024 | 10:06 AM
zcarmaniac's Avatar
zcarmaniac
Thanks,,,totally forgot,,,this allowed me to open the hatch,,,time to change the battery
Old Dec 12, 2024 | 11:18 AM
Vette Jockey's Avatar
Vette Jockey
Roadster Madness. 😠
St. Jude Donor '13, '20-'21
I hope you are feeling better, now! Good Luck, on your recovery.
Old Dec 12, 2024 | 12:13 PM
kodpkd's Avatar
kodpkd
How old is your battery?
Old Dec 12, 2024 | 04:11 PM
Grand Slam's Avatar
Grand Slam
Try changing the battery in your fob, too. That could be the problem.
Old Dec 12, 2024 | 04:32 PM
Makitso's Avatar
Makitso
Be careful opening and closing the doors with a dead battery, the windows
won't index and will scrape.
Old Dec 12, 2024 | 05:06 PM
TxLefty's Avatar
TxLefty
I'd try giving it a charge through the 12v port in the hatch area. I'm not sure how high a charge you can put through that port. But even a low charge rate should get you back to operating voltage overnight.
Old Dec 12, 2024 | 08:32 PM
RonC7's Avatar
RonC7
A battery maintainer may not charge a totally dead battery. Most need to see enough voltage to determine polarity. Most chargers can be set to charge a totally dead battery at the battery terminals.
The rear 12 V accessory socket is powered through a 30 amp fuse.
Ron
Old Dec 13, 2024 | 06:29 AM
449er's Avatar
449er
CF Community Team
Sounds to me that there will be a new battery in your future
Old Dec 13, 2024 | 09:45 AM
CraigStu's Avatar
CraigStu
If the battery is the original on your 2018 car, don't even bother charging it. Just replace it.
To Dead battery
