Flashing HVAC Lights?
Old Jan 11, 2025 | 10:58 PM
Gearhead Jim's Avatar
Gearhead Jim
St. Jude Donor '13
Default Flashing HVAC Lights?
A friend with a 2015 (?) C7 is on vacation in Arizona and sent me this email:
"An unusual thing started to happen.
The HVAC lights on the control buttons and the two temperature readouts started to flash on and off intermittently.
Tapping the dash and hitting bumps on the road do not seem to affect the flashing.
Have you heard of this on other C7's?"
I've not heard of this before, does anyone know the cause and cure?
There are several questions I could ask him to clarify the situation, but I'll get the collective wisdom of the Forum together before asking him.
Thanks.
Old Jan 12, 2025 | 07:31 AM
Interested in hearing about what you find.
Old Jan 12, 2025 | 10:55 AM
Undatakr's Avatar
Undatakr
Interesting, mine (2014 Stingray) flicker on occasion but do not go on and off. Does the fan quit when the lights are off? Everything seems to run fine with mine but the occasional flickering is annoying and distracting. I, too, will be interested in what you find.
Old Jan 14, 2025 | 10:37 PM
Gearhead Jim
St. Jude Donor '13
He says that when the HVAC lights flicker off, then he can't change the temperature setting.
I'm guessing a loose connection or failing module.
Your thoughts?
To Flashing HVAC Lights?
